Author Topic: tappet spec  (Read 1835 times)
tappet spec
« on: September 14, 2007, 08:07:09 PM »
Your preferred valve clearance spec is? Lookin' for single feelers for the under seat kit and need to know What the collective wisdom is on the correct intake & exhaust spec.  Didn't have 4 days to root thru snowbums site  [smiley=dizzy2.gif] [smiley=dizzy2.gif]Thanx
Re: tappet spec
« Reply #1 on: September 14, 2007, 08:21:29 PM »
Rich , I've been using .006 for intake, and .008 exhaust, the owners manual that came with the bike shows .004 intake, and .006 exhaust. The BMW shop manual I have shows .002 for intake, and .008 for exhaust. So go figure what it's supposed to be !!! My valves might be a bit noisier than they should be, but I've been told so many times loud valves are happy valves.
« Last Edit: September 14, 2007, 09:02:29 PM by Bob_Roller »
Re: tappet spec
« Reply #2 on: September 14, 2007, 08:34:01 PM »
Thanx Bob. Yes I also subscribe to the happy hammering sound when it comes to push rod motors. Off to the Dog Track for some expendable tools (Bob knows what that means)
Re: tappet spec
« Reply #3 on: September 14, 2007, 09:31:43 PM »
I adjust mine to the "loose" side of the .004 and .006 spec, so they are probably closer
to .005" and .007" - hearing the "ticky-ticky" is generally a good thing with the sewing machines...
Re: tappet spec
« Reply #4 on: September 17, 2007, 11:21:16 PM »
.006" intake .008" exhaust 03/1980 model with the smaller valves.  Sound like happy gnomes tapping lightly on china.  (Thanks to Nathan/Dean at Boxerworks)
thrang
Re: tappet spec
« Reply #5 on: September 18, 2007, 06:50:11 AM »
one the lose side, 004 inlet, 006 exhaust, for me.
Re: tappet spec
« Reply #6 on: September 18, 2007, 12:31:31 PM »
This is weird.  MY owner's manual says to use .004" and .008" clearances, intake and exhaust respectively.
billygoat
Re: tappet spec
« Reply #7 on: September 18, 2007, 08:40:52 PM »
 I hope I don't get in trouble for this but Snowbum says:
The R65/R45 models probably should have the valves set a wee bit looser, .006" intake and .010" exhaust is fine.
Those are the setting I use and I get better starting and less noise, in my opinion.
« Last Edit: September 18, 2007, 08:42:50 PM by billygoat »
Re: tappet spec
« Reply #8 on: September 18, 2007, 09:30:38 PM »
Having a bit more clearance also helps things run a bit cooler as well, which isn't a bad thing for these valves either.
Re: tappet spec
« Reply #9 on: September 18, 2007, 11:36:37 PM »
Those are the ones I actually have USED for the past 25,000 miles or so; I got the figures from his site as well.  My earlier post was just to point out how many different sources seem to indicate different clearances.  I still think that's weird.
Re: tappet spec
« Reply #10 on: September 22, 2007, 12:36:56 PM »
I am amazed at how many diferent setting there are for valve clearence!!!!
