Author Topic: Swingarm boot, anyone tried the Max version?  (Read 3512 times)
« on: February 18, 2014, 07:38:15 AM »
I'm in the process of trying to get the boot on the swingarm. Needless to say, it's a true PITA. I see Max has their own version, with a groove on the inside to help it seat. Anyone tried one?
Re: Swingarm boot, anyone tried the Max version?
« Reply #1 on: February 18, 2014, 07:49:33 AM »
No knowledge of the Max BMW aftermarket boot but I would be surprised if installation is much easier. Das boot is a mild PITA at best.
Having the rubber boot warmed up should aid in getting everything popped into place. Folks use a variety of different tools to persuade the little devil; just use caution not to poke a hole in the new boot.
There's a top and bottom position. OEM has it marked for you.
Good luck. I always draw a little blood on this job.
« Reply #2 on: February 18, 2014, 07:52:06 AM »
I am afraid its a 'right of passage' for any Airhead owner.
Great things will happen after you successfully get your boot on.
New horizons, New people will welcome you into their inner circle, you will get a feeling of great well being, people that you don't know will acknowledge your presence as a 'experten' from across the street, even.
And a serious lesson learned.  I.e. Don't remove your boot unless you really have to!
I tend to secure one end, the larger one to the swing arm, noting the orientation and the tab on the swing arm.  Clamp it into place.  The get yourself comfortable, lying next to your bike (you might be there for a while) and try to get the other side of the boot onto the gear box, using some sort of flat lever (like a flat blade screw driver - only be careful not to scratch up the alloy on the gearbox).  New ones are the worse.  Perhaps try stretching it a bit and warming it up - to body temp only.
Rev Light
« Reply #3 on: February 18, 2014, 08:08:52 AM »
You know what ?
Last time I had to change the boot, it was VeRy easy ! so I thought I was lucky.
A friend (grin) of mine installed his little daughter on the saddle to show her how cool it was. She decided to go on the floor by herself and opened the boot with her shoe lace pin... My super nice boot lasted for less than a week....
So I envy you  :-? ....
« Reply #4 on: February 18, 2014, 08:12:50 AM »
Are the tabs on the swingarm intended as "stops", to prevent the boot sliding on too far?
The swingarm is on the bench right now, im only working on this end of the boot. Getting the boot on the swingarm is easy enough, I'm struggling with then getting the clamp on. I've had the boot under a 100w light bulb to warm it up.
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #5 on: February 18, 2014, 09:18:53 AM »
Al,
I start with securing the boot at the swingarm housing as Steve explains.  The boot should have the word "oben" molded in it. That portion of the boot should go "up" or "above" and at the transmission side. Be sure to slide the boot under the metal tabs (tabs are on the top and bottom if my memory serves) on the swingarm and secure the strap under the tabs as well.  Now you're half way home. Carefully work the front of the boot around the transmission housing and secure the strap.
As a footnote, I had trouble with the length of the strap screw not being long enough my about 2mm for the swingarm side and obtained a longer screw from the local hardware store.  It lessened the frustration. And, my boot was ordered from Ted Porter at the Beemershop.
Here's  a photo of the boot and strap under the metal tab.
« Last Edit: February 18, 2014, 10:03:32 AM by Mike_V »
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
« Reply #6 on: February 18, 2014, 10:13:40 AM »
I have actually used a puncture repair kit as a bodge fix on one of these boots.  It lasted ages.
In fact it was only my embarrassment at seeing the offending patch that made me change it for a new boot.  It was only a little tear.
I felt better after..... ;)
Rev Light
Offline davidpdx
« Reply #7 on: February 18, 2014, 10:47:39 AM »
I just did this job this winter and found that having an extra set of hand on the other side of the bike to hold the boot in place while I moved it forward onto the transmission made a huge difference. Not sure if I could have gotten it by myself.
1984 R65 60K+
1946 Triumph Speed Twin
? Hunter S. Thomps
« Reply #8 on: February 18, 2014, 01:16:16 PM »
I made myself a tool out of a small screwdriver.
You have to heat the end of the screwdriver in order to bend it, otherwise it just breaks off...  :-[ lol!
It does not make the boot "slide on", but it is helpful.
« Last Edit: February 18, 2014, 01:17:15 PM by Rob_Valdez_79_R65 »
« Reply #9 on: February 18, 2014, 01:20:22 PM »
Congratulations to your hardware store!
That is a unique little screw, as I recall.
Offline Mike V
« Reply #10 on: February 18, 2014, 01:45:08 PM »
I see you can appreciate that little fact Rob.  Marshall's Hardware Store - it's an Airhead Candy Store.  If you have one in your area I highly recommend them.  You have to visit one to understand.  I replenish all my metric hardware, stainless and otherwise there.  In this case; an additional 2mm made a big difference.
Let's not forget the importance of the driveshaft flange bolts for this operation.  They should be replaced without washers.  A torque wrench extension that can be obtained from different airhead suppliers makes things easier.  If you do use the extension, don't forget to do the measurements and calculations for the adjusted torque bolt values.
Hope this link works showing the tool....
http://tinyurl.com/kq6nal2
Mike V. / San Diego
« Reply #11 on: February 18, 2014, 03:07:46 PM »
Thanks for all the tips, guys. I haven't had a chance to muck with it today.
Thanks for the pic, Mike V, I was trying to use the tabs on the swingarm as stops, rather than sliding the boot and clamp under them, so that seems like it will make a big difference.
I don't like the way the swingarm flange is tapered; doesn't seem like the best way to get a seal with the boot and a clamp that can't conform to the taper. But then who am I to second-guess those Bavarian engineers?  ;D
BTW, Max is out of stock of their custom boots. The parts guy told me they have only had one batch of 5 which sold out and they're due for another batch next month. So not much of a track record with those yet.
Offline Mike V
« Reply #12 on: February 18, 2014, 03:16:36 PM »
Al,
You bring up a good point - the flange or opening on the swingarm where the boot attaches is definately asymetrical in shape.  It's not your imagination.  But, if you're careful getting the boot slid on, it will seal with the help of the clamp. That was noticable during my installation also.
Keep us in the loop...
Mike V. / San Diego
« Reply #13 on: February 19, 2014, 12:25:00 AM »
My method for "torquing" the 4 driveshaft flange screws is to use the 10x12 mm ring spanner included in the OEM tool kit.
The rear brake has to be assembled for this.
Get all four (generally new) screws threaded into their respective CLEAN threads and all snugged up evenly.
Put on a leather work glove, and with substantial shoes on, put the 10mm ring spanner on the first screw with the screw at about 1 o'clock (with the "clock" being the output flange).
Stomp down on the foot brake as hard as you can and push down on the short 10mm spanner with all your might.
Repeat for the other three screws.
I NEVER in 35 years had a screw come loose using this method.
If you don't have the OEM spanner, they are available, part # 71 11 1 237 847.  ($12.27 USD)
Just beware - these fine quality tools are addictive!  If you don't already have a complete set, you will begin trying to rationalize getting one!
« Reply #14 on: February 19, 2014, 05:25:04 AM »
My driveshaft flange screw install and torque down is just like Rob's.  [smiley=thumbup.gif]
And whenever the shop or tech article states, "Use the special factory tool..." I start knocking together my own "special tool" which usually turns out to involve whacking a large diameter socket with a stout hammer.
