Author Topic: New R65 owner with gearbox out need Help!!!  (Read 4058 times)
raygun
« on: June 17, 2007, 08:18:18 PM »
Ok, the final gear is out, the paralever is out, the gearbox is out and the splines both input shaft and clutch plate look perfect. So what could be causing the grinding slip? It is not the splines. Is it the driveshaft? Is it the bevel gear at the final drive? or would it be in the gearbox? Again it would slip consistently in all gears. You could accelerate gently without it slipping but if you twist the throttle some it would slip with a ratcheting sounding grind. Please help. Ray
Re: New R65 owner with gearbox out need Help!!!
« Reply #1 on: June 17, 2007, 08:44:28 PM »
Look at the final drive to wheel splines, although I would suspect if they were worn completely off you wouldn't move at all - period!  There are some splines where the driveshaft fits to the final drive but don't reckon I've ever heard of anybody ever stripping them.
« Last Edit: June 17, 2007, 08:46:55 PM by admin »
raygun
« Reply #2 on: June 17, 2007, 09:34:30 PM »
Justin, those points look good and the final feels tight. I'm wondering if it isn't in the driveline. Maybe the shock absorbing cam or the splines on the shaft. The driveline lube had the most gray matter of the 3 lubes. I'm hoping it is not the gearbox. The lube there looked very clean with just some very fine particles and one sliver.
airhead
« Reply #3 on: June 18, 2007, 06:08:25 AM »
Well, that was a blow to our credibility!!
Might well be the shock absorber spring on the gearbox input shaft in the box gone south . Not unheard of for them to break. Haven't heard of the input shaft main splines (inside the gearbox) shearing, but hey, anything is possible. Another thing could be the actual shock absorber cam, when I overhauled my spare box from a '79 R65, one of the cam lobes was worn excessively, and the corresponding lobe on the main cog was partly broken and had another crack forming, so there's a possibility.
Bill...................;-)
« Last Edit: June 18, 2007, 06:51:28 AM by airhead »
« Reply #4 on: June 18, 2007, 06:50:15 AM »
Bill, I thought the '79 had the solid driveshaft - so much for thinking!  I'm out of ideas.  :P  I never had any credibility anyway so no damage done...
« Last Edit: June 18, 2007, 06:51:04 AM by admin »
airhead
« Reply #5 on: June 18, 2007, 06:58:23 AM »
I was talking about the shock absorber on the input shaft (now edited), though the '79 R65 on was the first of the models to have the Cardan driveshaft, probably BMW was testing it on them before giving it to the bigger models.
Bill.......................;-)
« Last Edit: June 18, 2007, 07:00:29 AM by airhead »
raygun
« Reply #6 on: June 18, 2007, 04:30:20 PM »
The driveshaft definetly has the spring behind the female splines. I built a tool today to press the shaft and release the retaining clip. I'm headed out to do it noew, will keep you posted.
raygun
« Reply #7 on: June 18, 2007, 06:50:40 PM »
Ok, to recap, pulled gearbox, input splines and clutch plate spines are perfect. Pressed the drive line and removed the circlip and disassembled, and it all looks like new. Disassembled clutch and checked pressure spring and clutch plate, it is all good. The only 2 things that have not been inspected internally are the final gear and the tranny. Both feel fine when hand operated. Checked the tranny thru all gears and it is very smooth. The final gear is tight and smooth. It has to be in the final gear or the tranny though, because everything else has been inspected and checks out with no wear or damage. Has anyone took the final gear or tranny apart? If so lead me in the process please. Ray
« Reply #8 on: June 18, 2007, 08:01:09 PM »
I think Bill has had a tranny torn down, not for the faint of heart from what I hear...
« Reply #9 on: June 18, 2007, 10:22:13 PM »
I haven't taken apart my gearbox, and you've taken apart all the other bits that I've
ever looked into, so I'm afraid that I am at a loss to give you any additional advice/info.
Personally, I was thinking that maybe the diaphragm spring might be weak or hanging
up and not pushing against the clutch plate sufficiently.   If that isn't the case, and the spring in
the driveshaft checked out good, perhaps you may be in need of a tranny rebuilding specialist.
« Reply #10 on: June 18, 2007, 10:48:22 PM »
I second the clutch parts idea.  The springs do wear, so maybe it's not pushing hard enough to get good clutch engagement.  You did remove all the clutch parts?
airhead
« Reply #11 on: June 19, 2007, 06:19:42 AM »
Yep, done several now (very successfully by the way!!) and not as hard as your own self limitations will have you believe. You do need at least one special tool, but can be made at home. Below is a link to a very easily followed site that I used when I first repaired a box on a friends bike after he dropped an output shaft bearing. Since then I've done another couple of boxes for friends, and another spare for myself and have one on the bench at the moment for my 90/6. You will easily see in one of the photo's the shock spring and cams on the input shaft I alluded to earlier.
http://homepage.sunrise.ch/mysunrise/joerg.hau/mot/gearbox.htm
I see you have posted on Boxerworks, you may get some more ideas there, but we have been known to have a bit of fun as well, so maybe expect a bit of thread degradation.
Bill................;-)
raygun
« Reply #12 on: June 19, 2007, 04:48:29 PM »
Thanks Bill, I'm going to have to make a couple of tools and then I'll tear into it.
Lowen
« Reply #13 on: June 19, 2007, 08:45:27 PM »
A worn throwout bearing piston would allow the clutch to slip. Had to replace mine a few years back.
raygun
« Reply #14 on: June 20, 2007, 06:45:20 PM »
Ok, I got the tranny cover off and pulled the input shaft. "Lo and behold" there was the gear wheel with both its ears knocked off. And it looked about as sad as me when this big ol' boy tried to knock my ears off. I kept mine. Well any way it is nice to have gotten to the root of the problem. I owe a debt of gratitude to the many folks on the web that helped see me threw it. THANKS ;)
« Last Edit: June 20, 2007, 06:45:59 PM by raygun »
