Author Topic: CHANGING THE OIL SEAL ON THE FINAL OUTPUT DRIVE  (Read 1448 times)
balibeemer
« on: August 30, 2008, 12:15:15 AM »
HELP!  Oil is leaking from the final output drive - all over the rear brake shoes. I have checked the Haynes manual unsuccessfully - Are there any tricks to changing out the oil seal? :-[
Re: CHANGING THE OIL SEAL ON THE FINAL OUTPUT DRIV
« Reply #1 on: August 30, 2008, 12:12:56 PM »
Even though it's a big ol' diameter seal, same precautions as any others. I used a small wood block and a tack hammer to GENTLY drift the seal home in a circular pattern of tap...tap...tap. My local bearing supply vendor had to special order the seal at about $18.00USD plus another $10.00USD shipping.
Watch out for the drive splines. Don't want to nick the seal's lip. Also, do the spline lube chore while you're in there.
willr65
« Reply #2 on: August 30, 2008, 01:05:17 PM »
Are you 100% sure it's the big seal?????   It could and may be the "O" rings sealing the brake operating arm leaking. Much easier to fix!
« Last Edit: August 30, 2008, 01:05:39 PM by willr65 »
« Reply #3 on: August 30, 2008, 08:56:03 PM »
Second the motion made by Will...
balibeemer
« Reply #4 on: August 31, 2008, 01:09:46 AM »
I never thought of that! - And how do I replace the 0 ring seals for the brake operating arm?
Offline donbmw
« Reply #5 on: August 31, 2008, 01:21:14 AM »
Remove brake shoes then removed brake arm and push brake shaft out of final drive.
Don
willr65
« Reply #6 on: August 31, 2008, 05:35:09 AM »
Brake operating arm showing three "O" rings. You need to remove the splined arm off the shaft and also the brake shoes. The shaft should just pull out with a little persuasion.
« Last Edit: August 31, 2008, 05:36:51 AM by willr65 »
« Reply #7 on: August 31, 2008, 01:30:40 PM »
...and us folk here in the Colonies usually score O-rings at the local hardware store. Cheap.
« Reply #8 on: August 31, 2008, 08:41:35 PM »
While it is most likely a rubber seal, I had a slight oil leak in my final drive that turned out to be  a bad/loose cover bolt and washer.    Cleaned up the area where the bolt & washer contact the inside cover of the final drive and replaced bolt and washer -> no more leak.   I don't know why it started to leak there, but it did, and has been tight ever since..
