Author Topic: Hey Everyone New Member  (Read 2451 times)
Offline Oconner
  • Sunny So Cal.
« on: July 22, 2015, 04:39:10 PM »
Last weekend pickup a 82 r65ls with 19500miles! I have an old 72 Honda and a 2013 600 sport bike. The Beemer puts as big if not bigger smile on my face! What a great bike. Have been reading the tech. posts and learning lots. I know I will have lots of questions, hopefully not all stupid! See you guys on the road.
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Re: Hey Everyone New Member
« Reply #1 on: July 22, 2015, 08:23:10 PM »
Welcome.
The only stupid question is the un-asked one.
« Reply #2 on: July 22, 2015, 08:41:46 PM »
I don't know about that Tony. I asked my ex if she wanted to get married. That was a stupid question that should have stayed un-asked!  :D
Welcome to the asylum Oconner!
« Reply #3 on: July 22, 2015, 10:43:48 PM »
The question wasn't the problem. It's what you did with the answer
« Reply #4 on: July 23, 2015, 05:40:07 AM »
Your LS appears to be a totally unmolested bike which is a rare find indeed. Amazing and with such low mileage.
Noted the earlier ATE brake calipers on your twin disc model. Seem BMW Motorrad was using up the parts bin inventory prior to the switch over to Brembo calipers. My '81 and '83 R65s both have Brembos but with the usual NA import's single front disc.
An important maintenance item is proper lubrication of the final drive and transmission/clutch spline gears. Honda MolyLube is your friend. That and a good shop manual: Haynes, Clymer or both. The manuals detail what services are recommended and their mileage intervals.
The Airheads are relatively simple motorcycles and easy to maintain. Corrosion of wire terminals and connections is common.
Welcome aboard. We're all pretty much friendly fire 'round here.
Offline Oconner
  • Sunny So Cal.
« Reply #5 on: July 23, 2015, 11:01:24 AM »
Monte I think I recognize you in the picture! HA. THanks for the advice. Already have the Haynes. Going to be doing all the lubing and oils soon. From what I gather the bike is pretty much all orig. The only thing different the PO put different bars on, which make the throttle stick. I will do a new post regarding this and possible solutions, pic's etc.
Thanks Everyone!
'82 r65LS
'72 Honda CL 350
'13 FZ6R
« Reply #6 on: July 23, 2015, 01:27:53 PM »
Thanks Everyone!
BMW requires 22mm diameter handlebars. Some folks will fit the more common 7/8" bars and end up with a situation like yours. Over-tighten the lever perch on a 7/8" and you will very likely break the perch. The Flanders Co offers many 22mm bars for BMWs. Check 'em out here: http://www.flandersco.com/index.html
"Monte I think I recognize you in the picture!"  Yeah, I get that a lot. Nurse Ratched is always on my case.
Zamp
« Reply #7 on: August 05, 2015, 05:27:00 PM »
welcome.. I picked up same color SL a few months ago. I'm in the Torrance area.  Got some good info on this forum, helpful folks.
Looks good, loads of fun on the twisty bits.
Offline Oconner
  • Sunny So Cal.
« Reply #8 on: August 06, 2015, 10:26:34 AM »
Hi Raul, we should see if we can get some more airheads together sometime and do a tech day here in LA.
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Zamp
« Reply #9 on: August 06, 2015, 05:17:35 PM »
Oconner
The Airhead club is hosting a tech day on Saturday August 22 at 19832 Trident Ln. Huntington Beach CA. I joined them after buying the LS.
There is also Valdi at Moto zone he's an independent mechanic in Torrance,
« Reply #10 on: August 06, 2015, 06:27:21 PM »
Oconner
You guys need used Airhead parts, look up Larry Stonestreet "Stoner's Stash" at most any SoCal ABC Tech Day.
Offline Oconner
  • Sunny So Cal.
« Reply #11 on: August 07, 2015, 10:06:34 AM »
How do I join?
'82 r65LS
'72 Honda CL 350
'13 FZ6R
« Reply #12 on: August 07, 2015, 02:35:46 PM »
How do I join?
Suggest you look over the Airheads Beemers Facebook page. Start here:
https://www.facebook.com/groups/airheadsbeemer/?fref=nf
The actual Airheads Beemer Club (ABC) of which I was a member for several years, is a dues payable "club' that's going through some challenging times. Struggling with prior leadership issues and membership has been dropping steadily. Time will tell if the ABC organization will remain viable or not.
