Author Topic: lipstick on a pig  (Read 1650 times)
DerekM
lipstick on a pig
« on: May 21, 2014, 12:25:59 PM »
Since i had the transmission and rear end apart to grease the splines and inspect the swingarm i figured i would spend the $5 on a spray can since powdercoating might be a longer time away than the bike would like.
My sub frame, battery box, swingarm and rear portions of the frame looked like it was subject to chemical warfare courtesy of a previous battery, so i took some 150 and 400 grit and followed it up with some navel jelly. Topped it off with a coat of spray on rust cover paint in satin black and the bike looks so much better. swing arm and battery box are up next.
Re: lipstick on a pig
« Reply #1 on: May 21, 2014, 12:42:31 PM »
Your "before" shots remind me of something...
Nice work. One thing leads to another.
Before you know it, you'll be buying SimiChrome to shine up the tops on your Bings.
 [smiley=whistling.gif]
« Reply #2 on: May 22, 2014, 05:14:11 AM »
Very nice indeed. But yes, it is a slippery slope  ;)
« Reply #3 on: May 22, 2014, 08:14:53 AM »
Take no notice of them... go ahead and polish the carb tops.
...and while your at it make sure all the screw slots line up. ::)
« Last Edit: May 22, 2014, 08:22:05 AM by bhodgson »
« Reply #4 on: May 22, 2014, 08:24:04 AM »
Crikey, Barry! You've gone n' buffed the domes clean away from the Bings! I do luv me screws lined up...
 [smiley=ROTFLMAO.gif]
DerekM
« Reply #5 on: May 22, 2014, 11:31:12 AM »
Screws get lined up depending on the medication at hand. Beer, wine... Whiskey.
Looking much better.
arvo92
« Reply #6 on: May 22, 2014, 11:58:13 AM »
Nice result for a few bucks.
Makes me think that I should do the same as the rear end is coming off when my holiday starts in couple of weeks.
Looking much better than I would have thought for a spray can.
DerekM
« Reply #7 on: May 22, 2014, 12:53:12 PM »
Yeah, spray can is fine for some applications. Long term proper restore needs powder coating or a real paint, but for a clean and reassemble this will do.
DerekM
« Reply #8 on: May 29, 2014, 12:21:18 PM »
I had to buy another can of paint to get everything coated well, but very pleased with the results. before and afters below.
