Author Topic: choke pulls  (Read 1955 times)
Offline wilcom
choke pulls
« on: August 12, 2012, 08:17:07 AM »
Another thread pointed me to the http://boxermetal.com/#ecwid:category=3027386&mode=product&product=13179793 site and I found these.  Pretty "sano" and you get to do away with two cables and that pesky reach under your leg a 1/2 block from home thing.   $49 for a set of 2
You handle bar choke guys.........never mind
« Last Edit: August 12, 2012, 10:00:34 AM by wilcom »
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: choke pulls
« Reply #1 on: August 12, 2012, 10:01:32 AM »
I bought a chokeless perch to do away with mine. Was going to get an airbox mounted lever until I saw these.
Offline jakebass12
  • double clutching diesel demon.
Re: choke pulls
« Reply #2 on: August 12, 2012, 10:44:56 AM »
there are some of those on eBay $50 a pair.  :o i think i can furnish my own somehow for only $10.  ;)
1981 bmw r65. 1981 kawasaki kz550
Re: choke pulls
« Reply #3 on: August 13, 2012, 09:51:16 AM »
I am using a pair of cut down push-bike spokes, and the nut that goes inside the rim.  Seems to work quite well and it was free - I had a couple of spare spokes!
You might be able to see them in this picky....$50...pah!
Re: choke pulls
« Reply #4 on: August 13, 2012, 01:37:22 PM »
Steve, if you keep posting pictures of that bike I'm going to keep coveting it.   Just saying.
Re: choke pulls
« Reply #5 on: August 14, 2012, 02:24:17 AM »
Sorry Ed, especially in this case, you cannot really see what I was going on about except for the very top of the spoke and nut poking above the top of the carburetter and no cable.
One of these days I am going to revisit this bike and re-incarnate her.  Its been 10 years.  Almost time for a refresh and a colour change.
Offline wilcom
UPDATE....Re: choke pulls
« Reply #6 on: November 09, 2012, 10:08:29 AM »
I got around to installing one of the choke pulls since I had the carb off fixing the leak.
I have a problem, not earth shattering, but one that shouldn't have been there for $50......  The cable is arc'd to cause friction so the pull will stay up when its up and down when it's down,,, good idea.
The set screw that hold the plastic knob on the cable is so small on the plastic knob that it slips off when you pull the choke up. ( bad idea)  When I tightened it I just rounded out the allen screw never getting it tight enough to keep it from coming off.  The set screw is just too small to do the job or should have been made out of stronger material so you could lean on it a might before it rounded out the allen.
I don't mind paying for a great idea without getting much hardware in return, but I don't want to have to fix it when it gets here.
You might consider that before you send off your 50 clams
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: choke pulls
« Reply #7 on: November 09, 2012, 10:25:38 AM »
Have any pictures of what you have there, I have a handlebar mounted choke, so I'm not real familiar with the '78-'80 year choke  assembly .
