Author Topic: Push starting  (Read 2478 times)
Offline Air4Life
Push starting
« on: September 17, 2011, 03:23:09 PM »
Can these shaft driven cycles be push started without causing damage?
sold:
1983 33.8 E. Oil & Trans ?
Batt 10/06/2011
RearT 35.5 Spline 7/12 &
T.O.Bearing
C.U. Paste 5/12
Re: Push starting
« Reply #1 on: September 17, 2011, 04:06:38 PM »
You bet they can! Le Mans starts are fun.
Before I redid the diode board and swapped in a solid state voltage regulator on my '81 R65, I got pretty good at the run n' bump drill. Third gear worked best for me.
The problem is the alternator -charging system doesn't kick in a charge to the battery until 2-3K rpm. If you putt around town with mucho stop and go, you'll drain the battery in a couple days, max.
A Battery Tender[size=9]®[/size] kept plugged in will eliminate the issue or just keep the revs up and, as one of our members was so aptly advised, "don't ride like a wuss." ;D
Offline Air4Life
Re: Push starting
« Reply #2 on: September 18, 2011, 08:27:31 AM »
Yep, I tried the top gear and that wasn't much help.  I agree, I too found 3rd to be the right mix, after some trial and error.  Also, removing the cases helped greatly.   ;)
Yes, I've noticed that its a marginal charging system.  I've been using the tach. to stay in the 3-4 K range (thanks to a member or two here).  That seems to be a nice balance for suburban riding.
It gets stored in a cargo trailer.  I have to look into getting a solar panel for the roof.  I bet I can find a way to trickle charge from that...
Thanks, and be careful out there...
« Last Edit: September 18, 2011, 08:31:44 AM by Air4Life »
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
Offline Air4Life
Re: Push starting
« Reply #3 on: September 18, 2011, 08:33:13 AM »
By the way, I normally don't store it with the centerstand down.  Harbor Freight had a pivot chock that I bolted down.
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
Re: Push starting
« Reply #4 on: September 18, 2011, 11:10:57 AM »
If you have a bike with electronic ignition, with a low voltage condition of the battery, the ignition will most likely not work .
Below around 9 volts, the solid state components aren't working very well, if at all .
Offline Air4Life
Re: Push starting
« Reply #5 on: September 18, 2011, 11:52:12 AM »
Yes, thanks, good to know.  I had jumped it first to get it going, but then I had to shut it down.  When I went to restart I made a bump start effort that worked.
When I first got it I was riding every day, but then soon slacked off to where I now  notice the issue is more pronounced.  I will have to move back to AZ where I can ride nearly everyday.  Look out. :P
« Last Edit: September 18, 2011, 11:54:22 AM by Air4Life »
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
Re: Push starting
« Reply #6 on: September 18, 2011, 01:01:51 PM »
Where was that picture taken, Oak Creek in the Sedona area ?
Offline Air4Life
Re: Push starting
« Reply #7 on: September 18, 2011, 03:12:29 PM »
You win.
This day, I hiked from town to here.  ...maybe 2 miles.
« Last Edit: September 18, 2011, 03:13:08 PM by Air4Life »
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
