Author Topic: I am new (here)  (Read 1845 times)
Kingenglishman
I am new (here)
« on: May 20, 2011, 10:43:26 PM »
Greetings from Holland.
My name is Andy
35 yrs young/old (varies on a daily basis sometimes young sometimes old)
Self Employed as an auto detailer and work part time in a funeral home.
3 kids two boys 16 and 2 a daughter of 14.
a wife and a dog.
Recently bought a fine looking r65 from 79 with just 56000 kms on it.
it was sat still for at least 7 years but started yearly.
picked it up yesterday changed all fluids and plugs also a new battery.
started up great but rode not very great.
need to set the carbs.
it has all the original parts still on it including the tyre pump/user manual/first aid kit/ and tools.
I have also got a chopper but was amazed how agile the r is.
i will try to post some foto's tonight.
Re: I am new (here)
« Reply #1 on: May 20, 2011, 10:59:18 PM »
Welcome Andy!
I think that it has been sometime since we;ve had a member on the forum from Holland.   I think that you need to make another post or two before the forum will let you post a picture, so go ahead - we love to see pictures!
-Mike
Re: I am new (here)
« Reply #2 on: May 21, 2011, 05:29:55 AM »
Good to hear from you Andy! Widening our international exposure is so encouraging for this forum! With your R65 having sat for 7 years even though it was run yearly may still have some issues based on age of rubber, metal corrosion, old grease that will need some attention in time. You will find this forum very good for answering all and every question with informative and patient replies so never hesitate to ask any question.
So what was the problem regarding the running poorly aspect? Hesitation? Hard starting? Idling rough? Poor acceleration? etc?
They can be generally cold blooded bikes and seem to need to be warmed up before smoothness and idling well kicks in. At least my LS needs to be warmed up! But I am in Canada  ;)
Re: I am new (here)
« Reply #3 on: May 21, 2011, 09:17:42 AM »
Hi, Andy. Welcome to the R65 Asylum... once interned, there ain't no escape.
A couple other ideas for you:
Consider flushing out the fuel tank and doing a close examination for potential rust and/or flaking of any tank liner material. The carb float bowls are likely in poor shape due to fuel deposits left by evaporating fuel. Could be a clogged fuel/air orifice, damaged diaphrams, clogged jets, blah, blah, blah.
Research the site for carb overhaul info and do only one at a time so you'll have a reference when the senior moments strike. The enrichener units, plus the Bing main carb body, have "handed" components; ie: left-side only and right-side only.
Are you running the old, metal-covered spark plug caps? Status of plug leads and coil/s? Corroded wire connections can play havoc with proper running.
A good manual is very helpful. Lots to do.
Kingenglishman
Re: I am new (here)
« Reply #4 on: May 21, 2011, 10:32:57 AM »
Thanks for the warm welcome.
The problem with idle is that it revs high idle and then drops down till it stalls.
What i have done already is,
New oil
plugs,
filters,
cleaned the carbs
tank inspection (no rust or corrosion whatsoever)
new battery
replaced all fluids.
Re: I am new (here)
« Reply #5 on: May 21, 2011, 12:27:48 PM »
...The problem with idle is that it revs high idle and then drops down till it stalls.
Have you had an opportunity to inspect the ignition points and advance mechanism inside the Ignition Trigger Unit (ITU)? Commonly referred to as the "bean can", this item, plus correct ignition timing, can have a large effect on idle revs.
Lots to do. . .
Re: I am new (here)
« Reply #6 on: May 21, 2011, 01:04:14 PM »
Welcome Andy i used to be a regular visitor to the Netherlands which bit are you from ? come to England and we will find you some hills to ride.
Check the connecting hose from the carbs to the head they tend to harden and crack leaking air from the joint causing the revs to rise and run "Lean".
Dizerens5
Re: I am new (here)
« Reply #7 on: May 21, 2011, 02:16:35 PM »
Hello Andy I also have a 79 and it's beautiful to ride and to see, you should not have too much trouble setting up. Good to see someone from NL my wife of 40 years was from there (Harderwijk).
Kingenglishman
Re: I am new (here)
« Reply #8 on: May 21, 2011, 05:15:09 PM »
I am from the hague and i go to england once every three months.
my family is british and still lives there i was born in Liverpool so a scouser lol.
And constellation harderwijk is about an hour and a half away from me.
very cool to see the love to the dutch LOL thanks guys.
As regards the r i am a little bit handy so any input is welcome.
so if anybody knows of any how to's regarding the suggestions that would be greatly appreciated.
Cant wait to get her running sweet  :D
Re: I am new (here)
« Reply #9 on: May 22, 2011, 02:52:41 PM »
  :D[/quote]
Hey ho nobodys perfect
Kingenglishman
Re: I am new (here)
« Reply #10 on: May 22, 2011, 03:38:29 PM »
  :D
Lou[/quote]
Hi lou true nobody is perfect atleast i am a scouser that rides a airhead lol ;D
« Last Edit: May 22, 2011, 03:39:30 PM by Kingenglishman »
Kingenglishman
Re: I am new (here)
« Reply #11 on: May 22, 2011, 03:56:29 PM »
http://www.youtube.com/watch?v=mZfi1v7Zclg&feature=youtube_gdata_player
Short video of the r
Sorry for the heavy breathing had a bad hayfever attack
« Last Edit: May 22, 2011, 04:41:17 PM by Kingenglishman »
