Author Topic: Orange peel  (Read 1730 times)
Orange peel
« on: August 13, 2010, 10:16:36 PM »
Painters in the group will know what that is. I'm about to purposely destroy a new lacquer clear coat with some 2000 grit in the hopes I can buff it back out. Any suggestions on polishing compound(s) for the owner of a random orbit buffer?
Re: Orange peel
« Reply #1 on: August 13, 2010, 10:39:51 PM »
I'll have to look in my garage - I think that I had a can of Simonize or Turtle Wax brand buffing compound that worked OK
Crossrodes
Re: Orange peel
« Reply #2 on: August 13, 2010, 11:29:06 PM »
Let us know how it turns out.  The 2000 grit may be all you need.
Re: Orange peel
« Reply #3 on: August 14, 2010, 07:48:52 AM »
For the non-painters in the group:
http://en.wikipedia.org/wiki/Orange_peel_(effect)
Re: Orange peel
« Reply #4 on: August 15, 2010, 05:12:04 AM »
On lacquer I would knock down the high spots with 600 then finish with 800.  Or, skip the 800 altogether.  Buff with 3M Imperial Micro Fine...
Re: Orange peel
« Reply #5 on: August 15, 2010, 10:14:07 AM »
Some 2000 grit used with a foam sanding block took it down pretty well. I was chicken to make it all flat so there is still a slight imperfection here and there. I took the low cost route and used some Turtle wax rubbing compound and my el cheapo Sears buffer. Damn! came out really good. I'll be taking a junk tank down off the shelf next for some more practice. I think I'm getting hooked on this painting stuff. At least as long as it's a simple one color finish for now.
Re: Orange peel
« Reply #6 on: August 15, 2010, 10:27:54 AM »
Rich, are you painting the LS, or the British bike ?
Re: Orange peel
« Reply #7 on: August 15, 2010, 10:37:21 AM »
Bob,
I'm just doing a side cover on a silver R65 that came primed. Have a pretty good paint match and now I'm starting to think of freshening up the LS. Drop by if you have a mind to and I'll show ya what I did with limited funds.
Re: Orange peel
« Reply #8 on: August 15, 2010, 10:42:34 AM »
What did you finally come up with for a paint number for the imola silver ?
Re: Orange peel
« Reply #9 on: August 15, 2010, 11:31:20 AM »
I used a supplier that does not deal in Glasrut paint. they also seemed unable to match the BASF formula [060 imola silver] when I handed it to them. So It was a session out in the sunlight matching chips to the cover. From the supplier in Mesa I came up with a MA072.10 in BASFs LIMCO line. A nice silver metallic that is perhaps a slight bit more smoky and a touch more flake than stock but a very close match. I do or did have the BASF formula printed out and for a second go of it I'm going to try "The Paint Library" in Phoenix as they are listed as a Glasrut supplier. If you are contemplating a repaint of the LS this may help
http://www.bmbikes.co.uk/paintcodes/silvers.htm
along with
http://color-online.glasurit.com/
and
http://color-explorer.rmpaint.com/
The Mesa store does sell the RM line of paint but were baffled by the formula I gave them right from the BASF web site. It was a disappointing exercise with them as their grand store gave me high expectations.
Re: Orange peel
« Reply #10 on: August 15, 2010, 12:56:48 PM »
Is this Space Age paint supply ?
They've got some unusual engines in their showroom .
Crossrodes
Re: Orange peel
« Reply #11 on: August 23, 2010, 09:03:43 AM »
MrRidden are you using a spray gun or rattle cans?
