Author Topic: R65 ATE caliper pistons, mufflers wanted  (Read 890 times)
cobleighb
« on: March 29, 2008, 05:44:36 PM »
1979 R65 ATE brake caliper - Is the piston available ? If so, what's a good source ? I have found ATE repair kits for caliper, but doesn't appear to include piston, only rubber parts and clips.
Still looking for crossbrace/headlight assembly, including bucket and lens. AND mufflers....would consider aftermarket, but prefer OEM used. Any ideas ???
Re: R65 ATE caliper pistons, mufflers wanted
« Reply #1 on: March 29, 2008, 08:34:24 PM »
IF your ATE is the same as mine, then I believe that Motobins in England sells them in stainless steel.  And that you need two.  I've never seen any others for sale, though I bet if somebody would send Justin a good one he could make them for a bit less than Motobins.   I could use 4 of them for my bike, but that would be close to $400.   :-[
« Last Edit: March 29, 2008, 08:34:50 PM by Ed_Miller »
« Reply #2 on: March 31, 2008, 07:01:59 AM »
I have "manufactured" two of them for the '82 LS and although they "appear" to work while cruising around the back yard I have yet to give them a proper road test...
« Reply #3 on: April 01, 2008, 08:00:49 PM »
http://www.motobins.com/displayfinal.php?function=show&subs=107b&title=%28ATE%29+CALIPER+R45%2F65
£48.00 per PAIR, Ed!  That is $95 for each caliper.  Very close to what I paid two years ago!
« Reply #4 on: April 02, 2008, 01:32:00 PM »
Hmm, I have been a war profiteer lately, working 12 hour overtime Sundays sometimes.  I should get a couple sets.
