Author Topic: Tracker Airhead  (Read 2371 times)
Tracker Airhead
« on: February 18, 2010, 05:57:15 PM »
I have no explanation for this other than it is is w-a-y cool. Pulled it off the Airheads Beemer List from a post that someone else had snagged the image off a blog out in cyberspace somewhere.  Monte
Re: Tracker Airhead
« Reply #1 on: February 18, 2010, 06:09:44 PM »
Well do you sit in it, on it, or just leave it under the car port?  That is weird beyond belief.
Re: Tracker Airhead
« Reply #2 on: February 18, 2010, 06:15:55 PM »
Thanks Monte!  That is great.  I'm betting it didn't corner real well.
The metal/paint work is great, though!
Is that a sidecar attached?
« Last Edit: February 18, 2010, 06:16:59 PM by Rob_Valdez_79_R65 »
Re: Tracker Airhead
« Reply #3 on: February 18, 2010, 07:13:08 PM »
I'd hate to put my foot down and have my shoelace or pant leg get caught in the track when I took off again!!! :o
« Last Edit: February 18, 2010, 09:51:23 PM by nhmaf »
Re: Tracker Airhead
« Reply #4 on: February 18, 2010, 09:21:58 PM »
Maybe you sit in the sidecar... :P
Re: Tracker Airhead
« Reply #5 on: February 19, 2010, 08:55:06 AM »
Wouldn't you like to be puttin' around in one of those babies at the Winter Olympics?   ;)
JDS
Re: Tracker Airhead
« Reply #6 on: February 19, 2010, 10:32:56 AM »
I think it has a sidecar that has its wheel powered too and you use the wheel brakes to turn it.
Re: Tracker Airhead
« Reply #7 on: February 19, 2010, 11:23:20 AM »
Could have done with one of them a few week back i may have been able to get out of the drive.
Re: Tracker Airhead
« Reply #8 on: February 19, 2010, 05:29:53 PM »
Additional info off the ABC list regarding the BMW Tracker...
This photo dates back to before the war and is of a modified BMW R12 and sidecar.
The track was apparently made from short sections of old tyres fixed together, so it was fairly flexible and ran in guide rolls under that cowling.
At a guess, turning the bars will twist the track enough to give a measure of steering while the guide rolls will prevent the front wheel crabbing over the inside of the track.
In another photo the sidecar wheel appears to be mounted onto a ski so
any braking of the sidecar wheel would be ineffective.
Drew Grant
TXRider60
Re: Tracker Airhead
« Reply #9 on: February 23, 2010, 09:22:50 PM »
QUOTE...I'd hate to put my foot down and have my shoelace or pant leg get caught in the track when I took off again!!!
Scary. Guess the only safe way to ride this rig would be in your Rollie Free Speedo (TM)... ;D
Re: Tracker Airhead
« Reply #10 on: February 26, 2010, 07:32:28 AM »
Scary isn't the half of it.  The mental picture of Monte in a speedo is just.....well, I had to put my brekky aside for now. 8-)
Dizerens5
Re: Tracker Airhead
« Reply #11 on: February 27, 2010, 12:06:48 PM »
If there are guide rollers they are not very close to the front wheel...I would imagine that turning the steering more than a tiny amount would cause the track to peel gradually away from the wheel, helped by its apparent sideways flexibility. Like removing a bicycle chain, you know...And never mind your pants leg, just think what it would do to you if the central part of the cowling fell off!
Re: Tracker Airhead
« Reply #12 on: February 28, 2010, 09:32:25 AM »
Korners like Krap. Klimbs like a Kat, or some other silliness comes to mind.
