Author Topic: My R65 is baaacck...  (Read 1738 times)
« on: April 05, 2007, 10:11:13 PM »
..from Boxerworks.  New valves, guides, springs, wrist pin bushings and rod bearings.  Also got the pushrod tube rings welded so that they will hold against the seals and not leak!!
Nathan said my exhaust valves were sharp enough to shave with so I guess I caught it in time and avoided a Joan catastrophy.
Time to ride again!!!!!   ;D
So far - NO LEAKS!!!!!!  and its quiet.  I'm going to ride it tonight...just because!
Greetings from Late winter Atlanta GA - 40 degrees and falling.....
« Last Edit: April 05, 2007, 10:11:59 PM by Semper_Gumby »
Re: My R65 is baaacck...
« Reply #1 on: April 06, 2007, 12:24:34 PM »
I can't remember:  how many miles are on it?
« Reply #2 on: April 06, 2007, 02:01:08 PM »
Glad to hear your bike is back in proper running order, Bill!    [smiley=thumbsup.gif] Now get out there and put some mileage on that baby!   Ride it like ya stole it!    ;D
« Reply #3 on: April 06, 2007, 08:02:50 PM »
I had my valves and seats replaced 9 years ago. I have the dreaded '81 model year that was prone to valve face plastic deformation, a technical term for rapid valve face wear. It started out as a timing chain replacement, progressed into exhaust thread repair, and when I got the heads off and looked at the exhaust valves, about 80 % of the valve face was worn away. The shop that did the overhaul was San Jose BMW, and they said that at best I had 5,000 miles before the exhaust  valves would have failed. I guess it's one of those areas that needs investigating if you have a high mileage R65.
« Reply #4 on: April 06, 2007, 09:10:36 PM »
Bill, you're gonna amazed as how it runs now!  My '81 R100 also had valves you could shave with at 75k miles and the difference after a valve job was remarkable!  Well, the different rings might also have had somethingto do with it...
Joan
« Reply #5 on: April 07, 2007, 10:28:13 AM »
...Nathan said my exhaust valves were sharp enough to shave with so I guess I caught it in time and avoided a Joan catastrophy...
Hey! I resemble that remark!  ;D
Hmmm... SG spells it catasTROPHY. Coincidence?
I think not.  ;)  Can't resist another look at my "trophy"....
I really did barf when I saw that the first time.
 [smiley=clap.gif]Anyhow, good on you SG!  And how fortunate you are to have Nathan right there!
« Reply #6 on: April 07, 2007, 12:15:09 PM »
For all of you out there like me who are afraid of doing long journies on their R65's because something might break..look at Bill's long journey last year and his valves must have been pretty close to being wasted then..nothing happened to him!! So....is it the luck of the Irish or the strength of the machine?
