Author Topic: Transmission Speedo port  (Read 1174 times)
Offline wilcom
« on: July 15, 2020, 04:55:59 PM »
I know some of you folks have gone to an after market speedo and tach set up. When you eliminated the speedo cable what did you plug the hole with ??  I didn't want to cut off the cable and ruin it for use later and/or if I went back stock,
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline tunnelrider
Re: Transmission Speedo port
« Reply #1 on: July 17, 2020, 06:55:30 AM »
Not having done that myself Wilcom and probably stating the obvious remember the speedo drive retaining bolt is also the transmission breather so plugging the top port should keep that bolt clear. I also recall the one time I visited that area is the speedo drive bush and cable boot are inexpensive so if you need to sacrifice them it's no problem. Perhaps something as simple as a rubber grommet stretched over top and down below the boot lip, sealed with silicone will suffice?
« Reply #2 on: July 17, 2020, 10:44:02 PM »
 I would  machine down a bolt on the drill press (pillar drill) to fit in the hole
