Author Topic: R65LS Fork Gaiters  (Read 3878 times)
Offline Kelvin
  • R65LS
R65LS Fork Gaiters
« on: August 30, 2019, 12:55:33 AM »
Back in the 1980s my R65LS had fine ribbed gaiters, at least 15 ribs. Current parts listing on both BMW and RealOEM list the bike without gaiters, something that I associate with the 1982 model run (but I'm aware that there was much variation).
According to Mr Boxer2Valve the /5 models have 13 ribs, and /6 and later have 11 ribs. My bike currently has the 11 rib versions installed. These are what seem to be offered as gaiters for the 'LS on sites like Motobins.
Does anyone know what happened to the old gaiters? Are they still available anywhere? It's been years since I've seen a pair, I'm starting to wonder if my memory is defective.
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
Re: R65LS Fork Gaiters
« Reply #1 on: August 30, 2019, 12:37:29 PM »
I  installed gaiters on my 81 R65, 13 rib type .
Got them from an aftermarket supplier  BMW dealership here in the US, it was Bob's BMW, or Capital Cycle can't remember whch one,  both on the east coast of the US .
I don't know how much this matters but when I bought mine I was told to get the 13 rib type, the 11 rib type may restrict the front fork travel .
I just checked capital Cycle and they have the 11 rib and state, not for R65 .
https://www.capitalcycle.com/Fork-Boot--Accordian-Type-WIth-11-Ribs_p_408.html
https://www.capitalcycle.com/Fork-Boot--Accordian-Type-13-Ribs_p_416.html
I put the Capital Cycle part number for the 13 rib type into RealOEM and it is a good BMW part number .
https://www.realoem.com/bmw/enUS/showparts?id=0214-USA-08_1967_T50_BMW_R50_2&diagId=31_0512#31422002115
Now whether they are still available from BMW I have no idea .
« Last Edit: August 30, 2019, 01:32:41 PM by Bob_Roller »
Offline tiggum
« Reply #2 on: August 30, 2019, 01:51:20 PM »
Bob's shows 13 rib fork boots for $34.95 each under "reproduction parts".
« Reply #3 on: August 30, 2019, 03:57:51 PM »
Offline BPT
« Reply #4 on: August 30, 2019, 06:09:13 PM »
I remember reading somewhere (I thought here...?) to be sure to get the "good" ones, and I thought that Motobins was supposed to have them.  They show these 11 rib versions in the R65 section.  Are these not correct, or "good"?
I'd assumed that it was quality people were talking about and hadn't thought that the problem could be if they were too short.
« Reply #5 on: August 30, 2019, 07:23:05 PM »
I did some searching today about which boots were the correct ones for an R65 .
I found references for the 11 and 13 rib ones and also 14 or 15 rib boots . :D
So an honest answer I don't really know now !! ;D
I do know if you install one of these boots, the area for a clamp, is very narrow maybe .25 inches, 6 mm .
Regular worm gear clamps are too wide .
The BMW clamps are available for a reasonable cost .
Offline BPT
« Reply #6 on: August 30, 2019, 09:11:59 PM »
Haha, yes, it is very confusing. And I think that's why I hadn't gotten any yet.  I screenshot-ed that above because I couldn't copy the link for some reason. Right above the gaiters they have clamps as well, about £1.50.
I was thinking about putting in an order to Motobins and try to wait until I have enough stuff to make it worthwhile. Coincidentally, I was wondering about these for that reason.  I guess we can wait and see if anybody else can provide some input...........
« Reply #7 on: August 31, 2019, 02:18:28 AM »
I have been running the gaiters from Motobins since 2013 until I swapped out the forks for K100 ones.
My opinion is that the gaiters are just fine = and yes i bought a set for the K100 forks too.
Offline BPT
« Reply #8 on: August 31, 2019, 01:24:21 PM »
Thanks for the confirmation Tony.
One more thing I remember reading about: do thsee require the little breather tube thing?  I'd  read that on the bikes that came with these as standard, there was a little hole or notch in the gaiter and that lined up with a tube on the triple tree?
« Reply #9 on: August 31, 2019, 01:29:13 PM »
The boots I put on my '81 R65 hve a single breather hole in each one .
I've also seen references to a roll pin  I thnk it was on the lower triple tree .
None of my R65's have this .
Here's page from RealOEM, it shows a roll pin and a tube on the lower triple tree .
 https://www.realoem.com/bmw/enUS/showparts?id=0349-USA-10-1982-2471-BMW-R_80_ST&diagId=31_0293
« Last Edit: August 31, 2019, 01:37:36 PM by Bob_Roller »
Offline BPT
« Reply #10 on: August 31, 2019, 05:52:32 PM »
Yeah, Bob, that's what I was talking about.  I figured that as long as they had the hole they'd be able to "breathe" - but you know those BMW engineers....... Sometimes they have a reason for the tiniest things.
I mainly wanted to make sure it wasn't absolutely necessary since I've got custom triple trees and I knew I didn't have that setup.
     Thanks for the info
Offline Kelvin
  • R65LS
« Reply #11 on: September 09, 2019, 09:04:29 AM »
The later gaiters are functional (even if they look odd). They have a hole for the roll pin (breather), however, they foul the LS fairing, so don't properly engage. The original fine ribbed version had a plastic (neoprene?) ring for the top that had the hole for the roll pin in it (the gaiter went over the neoprene, the hose clamp over that).
Thanks all for the responses. I'm resigned to never seeing those early LS gaiters again.
Offline Kelvin
  • R65LS
« Reply #13 on: September 10, 2019, 03:39:02 PM »
Bullseye! They look correct, I'll follow up. Thanks.
Offline skippyc
« Reply #14 on: September 10, 2019, 05:16:19 PM »
Gaiters ain't always Gaiters I know a few brit bike people who have drought cheap gaiters only to have them fall to bits in less than 2 years.
