Author Topic: R65LS Fork Gaiters  (Read 3883 times)
Offline jp9094
Re: R65LS Fork Gaiters
« Reply #15 on: September 13, 2019, 03:52:48 PM »
Also found these on the Motoren- Israel site for 11.90 Euros. They are specific for the r 65 :https://www.motoren-israel.com/Shop/Telescopic-fork/Rubber-boot-for-R80G-S-15-folds::200460.html
Good luck!
« Reply #16 on: September 13, 2019, 04:01:31 PM »
The number on their website, 21-42-1-241-666 is a good BMW part number .
It also looks like some sort of filler ring is required at the top of the rubber boot, like the boot is too large for the R65 fork tube
https://www.realoem.com/bmw/enUS/showparts?id=0348-USA-06_1980_2471_BMW_R_80_G_S&diagId=31_0318#31421241666
« Last Edit: September 13, 2019, 04:04:26 PM by Bob_Roller »
Offline Kelvin
  • R65LS
« Reply #17 on: March 29, 2020, 05:49:46 AM »
Success!
The 14 ribbed gaiters from the G/S or ST models are what I remember from years ago:
o      https://www.realoem.com/bmw/enUS/showparts?id=0348-USA-06_1980_2471_BMW_R_80_G_S&diagId=31_0318#31421241666
o      02      Ring            2      31421241669      $6.97
o      03      Rubber boot      2      31421241666      $16.90
o      R 65 GS, R 80 G/S, R 80 ST (80-92) R 80 G/S Fork slider
They need the neoprene ring. There's a breather hole in the ring that attaches to a dowel on some bikes, but on the LS the ring sits low because it fouls the instrument bracket, so it doesn't need the dowel to expel air.
Pic shows the 11 ribbed version on left and 14 ribbed version on right.
Thanks all.
« Last Edit: March 29, 2020, 05:55:42 AM by Kelvin »
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
