Author Topic: Tyre Pressures On 1984 R65  (Read 2336 times)
Offline Adrian
  • The Old Hairy Biker Sez...
« on: March 10, 2020, 09:22:35 PM »
Hi - I've been on the Metzeler site to check the correct tyre pressures for my bike & the tyres that I have (newly) fitted. I have a Siebenrock 860 kit fitted so that adds a small amount of weight.
The recommended pressures front and rear are 32psi for both tyres. An extra 2 psi for a passenger.
I have panniers and a back rest so I'm thinking that 34psi should be the normal for the rear tyre solo and 36 psi with the boxes and passenger.
Advice form the fonts of all knowledge most welcome  ;D ;)
« Last Edit: March 10, 2020, 09:24:10 PM by Adrian »
1984 R65 (860)
Re: Tyre Pressures On 1984 R65
« Reply #1 on: March 11, 2020, 07:39:03 AM »
I'm a lightweight and not a fan of high pressures so I run pretty much what you suggest 32 front and 34/35 rear for solo riding with no luggage. I'd go up to 38 rear fully loaded.  Most people will be running higher pressures though.
« Last Edit: March 11, 2020, 07:39:57 AM by bhodgson »
Offline jp9094
« Reply #2 on: March 11, 2020, 12:32:10 PM »
At the r 65 LS rally last year I came across an r 65 LS with the following tire pressure recommendations under the seat (printed and pasted) : Front 38 Rear 42 ! Am currently running what Barry is using.
FWIW
« Reply #3 on: March 13, 2020, 05:38:05 PM »
You can experiment with pressures and see if there is a  change in handling .
I went up to 40 psi front and back and handling got quicker .
I keep them at 36 psi now .
Offline wilcom
« Reply #4 on: March 13, 2020, 10:22:30 PM »
I sart at 35 front and 40 rear, I won't add air till I lose 5 lbs. I like my front at 30, gives me good feel and feed back. If I start at 30 I have no margin for air loss.
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
