Author Topic: Replacement Fuel Cap Seal  (Read 1744 times)
Offline RickyM
  • 1980 R65
« on: October 20, 2019, 09:45:36 AM »
Afternoon all,
The seal on the inside of my fuel cap (1980 R65) has largely corroded (see first photo) so I want to replace it.
Am I right in assuming the circled part in the second photo is the right part? If not, any pointers where I can get a replacement? Also any advice on brake (ATEs) fluid, is any Dot4 ok?
Many thanks,
Ricky
« Last Edit: November 05, 2020, 08:08:29 PM by Justin B. »
Offline wilcom
Re: Replacement Fuel Cap Seal
« Reply #1 on: October 20, 2019, 09:57:22 AM »
Afternoon all,
Am I right in assuming the circled part  Also any advice on brake (ATEs) fluid, is any Dot4 ok?
Many thanks,
Ricky
I never knew that seal was there  had to go take my cap off to see it. ( yes, I'm not detailed oriented). Sure looks like the circled seal is the one you want.    Dot 4..... I use any fluid just don't use an open can, its cheap, get a fresh can.
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: October 20, 2019, 12:13:03 PM »
A bad seal can allow water into the fuel tank .
Also, check to make sure the drain tube in the filler area is open .
« Reply #3 on: October 20, 2019, 12:31:45 PM »
Hello,
The gasket circled is the good one as everybody pointed. Also do not forget to change the plastic skirt which is not present on the Motobins picture. It will help a lot in preventing water to enter the fuel tank recess. Heat it a bit in hot water to help putting it in it's place.
« Reply #4 on: October 20, 2019, 12:44:21 PM »
My cap seal fell to bits in a similar way to the photo above.  One of my O ring kits had a suitable temporary replacement which I fitted with the intentioning of adding the correct seal to my next Motobins order.  I never did get around to buying a replacement and the O ring has worked just fine for the best part of 10 years. Should it deteriorate in the future I still have several more in the kit.
Offline RickyM
  • 1980 R65
« Reply #5 on: October 20, 2019, 03:18:00 PM »
Thanks for all the advice guys, will let you know how I get on! Barry-good shout on the o ring, ill get a couple of these as a back up on the cheap as well.
