Author Topic: Torque valúes for 1979 R65  (Read 1266 times)
Offline Jschara
« on: June 15, 2019, 04:37:32 PM »
Can anybody confirm if these settings are right.
Drive shaft bolts 32NM
Swing arm pins 10NM
Swing arm nuts  105 NM
I got these from Chris Harris's Utube site.   I don't have a shop manual for my bike and I don't trust the Clymer 500-1000cc Twins 1970-1982 manual that I do have.
Thanks in advance,
Jim
Offline Jschara
Re: Torque valúes for 1979 R65
« Reply #1 on: July 02, 2019, 05:33:49 PM »
Am I the only one out there that is concerned about torque?
« Reply #2 on: July 02, 2019, 05:56:27 PM »
The BMW shop manual I have, shows 27+3 ft lbs for the 12 point driveshaft bolts .
Tighten the pin to 15 ft lbs, then back off and torque to 9 ft lbs .
I don't know the diameter and thread pitch, so I can't look up the standard torque value for the nut .
To convert Nm to Ft lbs, Nm X .737= ft lbs .
« Last Edit: July 02, 2019, 05:57:46 PM by Bob_Roller »
Offline Jschara
« Reply #3 on: July 02, 2019, 07:22:08 PM »
Thanks Bob,
Jim
« Reply #4 on: July 03, 2019, 08:20:48 AM »
This is from a post by Mike Valenti many years ago. He was meticulous guy so I would have no hestation in trusting the figures.  As bob said with the pivot pins go a bit higher and then back off and re-torque to the specified figure.  The trick is then not to allow the pins move while torqueing the locknuts.
« Last Edit: July 03, 2019, 08:24:49 AM by bhodgson »
