Author Topic: 12 V Heated gloves for a 1983 r65 LS  (Read 1362 times)
Offline jp9094
« on: December 08, 2018, 04:01:09 PM »
As winter is upon us here in the NE USA, I wanted to check out some heated gloves. However I am not sure if the electrical system on the bike can handle  them. I was looking at some Gerbring models, but could not find the current draw on the sites I looked at. The whole electrical system (Diode board, voltage regulator, rotor etc.) was changed in 2015. Any thoughts appreciated.
T.I.A.
Offline wilcom
Re: 12 V Heated gloves for a 1983 r65 LS
« Reply #1 on: December 08, 2018, 04:39:14 PM »
I have Gerbing heated gloves @ 30 watts and  Gerbing Jacket/jacket liner @ 80 watts....
MY ignition switch has a spot where I can run with no Headlight if there is an issue. There isn't much that is compelling enough for me to ride at night needing heated gear 8-)
« Last Edit: December 08, 2018, 04:40:00 PM by wilcom »
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: December 08, 2018, 11:19:16 PM »
 You should not have a problem with running gloves even with your head light on
If you want to run  gloves and a vest at the same time it will be marginal
If you switch all of your bulbs to LED you will have no problem at all running gloves and the vest
I can run a heated vest heated grips and  Aux  LED Flood light plus all the stock LED lighting with no problem
LED bulbs make High output charging systems almost obsolete
« Last Edit: November 07, 2020, 08:49:10 PM by Justin B. »
« Reply #3 on: December 09, 2018, 04:18:29 AM »
I just about get by down to -5 C  by heating my ordinary gloves and liners on a hot radiator before I set off on a 4 mile commute to work.  Any further than a few miles would make heated gloves essential though.
« Last Edit: December 09, 2018, 04:20:00 AM by bhodgson »
Offline R65Guy
  • I'd rather be ridin'
« Reply #4 on: December 09, 2018, 08:44:17 PM »
Things that help:
A good PWM type heat controller
Handguards
ATV Mitts / Hippo Hands
With handguards and ATV mitts I find I rarely use electric gloves anymore - they are just too bulky.
81 R65 & 16 R1200GS
