Author Topic: stripped final drive oil filler plug  (Read 1128 times)
kls1
« on: November 21, 2007, 08:38:53 PM »
hey guys,
sad sad news. I was just replacing and refilling my oils, when retighetning with my torque wrench and it over torqued and stripped out the bolt. Now I'm just worried I just did about 500 dollars worth of damage...someone talk me down from this cliff. Any suggestions on what to do next?
*sob*
Re: stripped final drive oil filler plug
« Reply #1 on: November 21, 2007, 08:52:34 PM »
You don't have too many options here, the stripped threads in the final drive case need to be replaced with a threaded insert, or drilled out and re-threaded for a larger plug.
I would suggest calling around to dealers and independent BMW bike shops in the bay area, to see if one can help you out.
For a short term fix, you could try to clean the area and use a sealant and the old plug, it may hold enough to get the bike to a shop, but I wouldn't consider it a permanent repair.
« Last Edit: November 21, 2007, 09:04:17 PM by Bob_Roller »
« Reply #2 on: November 21, 2007, 09:12:16 PM »
Probably if this ever happens to me I'll most likely re-tap and replace with a larger plug.  I've never understood the dinky little plug anyway, a cost reduction?  A beefier plug would make sense, in my opinion.  Then again, I like industrial strength looking stuff... ;D
kls1
« Reply #3 on: November 21, 2007, 10:02:17 PM »
thanks guys, that's what i was thinking needed to be done. I might just use a sealant as a temporary fix, take off the unit over christmas break, and have someone work on it then (to cut away a little cost).
« Reply #4 on: November 21, 2007, 10:18:34 PM »
It really wouldn't be very hard to run a tap through there.  Just coat it with sticky grease to capture the metal chips...  But, if you insist on having someone else do it I would find a reputable local small general machine shop instead of taking it to some specialist or the dealer - it ain't rocket science!  The shop I work at charges $50/hour (minimum 1 hour) for walk-in stuff like this
Crossrodes
« Reply #5 on: November 27, 2007, 09:18:03 AM »
I would use a helicoil.  I used one on a 1500 goldwing where the oil pressure sender threaded into an aluminum plate.  It was still in there 4 years later when I sold the bike.  It never leaked.
kls1
« Reply #6 on: November 29, 2007, 11:31:18 AM »
Hey guys,
Helicoil does indeed sound like the best bet. I've temporarily sealed the bolt with a little loctite. Curious if anyone can confirm what I got from max's microfiche -- that the screw size i'm looking to replace is a AM12x1.5? length? thanks all.
« Last Edit: November 29, 2007, 12:54:57 PM by kls1 »
