Author Topic: Instrument panel  (Read 1280 times)
Offline badgertom
Instrument panel
« on: May 22, 2018, 02:42:22 PM »
I never liked the instrument panel on the 1982 R65. So I'm planning to replace it. I have looked at the ACEWELL  2853.
Has anyone used the ACEWELL Digital Speedometer & Tachometer. Any problems with the wiring?
Offline wilcom
Re: Instrument panel
« Reply #1 on: May 22, 2018, 06:52:01 PM »
If you search our forum for "acewell" you will find a copious amount of information on the subject
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline peteremc
« Reply #2 on: May 22, 2018, 10:29:55 PM »
I have one fitted to my custom 1982 R65LS. Overall, it's a pretty good item. Easy to wire in, with good instructions with the item. It was very reasonably priced.
A couple of small things: The RPM read out (graphic, not digital/numerical) was really erratic when I first fitted it, but a few less wraps around the plug lead greatly diminished this issue. It's still not perfect, but is now pretty good. Also, the warning and indicator lights are almost impossible to see in bright daylight. Not really a problem as I've found that if you place the face of the gauge in some shadow using your hand you can read it fine. It really only annoys me when I leave an indicator flashing - I hate doing that! The numerical readout in the centre of the gauge is nice and clear, as is the RPM graphic readout around the edge of the gauge.
One other thing to remember, there is no allowance to hook up your charging warning light to the 2853 model - not sure about the others. You'll need to set this up independently. Don't (as I did) just leave this off because the circuit including the warning light is required to maintain charge to your battery. I learned this the hard way and purchased a universal light and 2w incandescent bulb and all was good.
peteremc
Offline jamestnewsonr65
« Reply #3 on: June 18, 2018, 05:02:37 PM »
I installed one on mine and it works really well. As Peter mentioned above, the rpm can be erratic but experimentation gets this working ok.
The only thing i've found is that the speedo can read a little slow unless you fiddle with the wheel measurements to get the correct speedo ratio. Also the digital pickup from the gearbox they do works well.
1981 R65 (box of bits).
