Author Topic: Oil pan leak and torque wrench setting.  (Read 1494 times)
Offline Lordcargo
« on: February 21, 2018, 05:26:23 PM »
Had a small oil pan gasket leak and noticed bolts were loose and had regular flat washers. Replaced the washers with lock variety and re-tightened bolts. Tightened to 3lbs/si which seemed good for the bolt size (6 metric). Still getting a little seepage and wondered what settings others use.
2013 Goldwing F6BD
Re: Oil pan leak and torque wrench setting.
« Reply #1 on: February 21, 2018, 05:43:54 PM »
Well, I think that those fasteners are best done by feel, rather than using a torque wrench.  A palm-ratchet is all you really need.
If this is an old gasket, it may be time for a new one.
If it is a new gasket, keep in mind that they compress and will need to be re-tightened after a short run-in.
« Reply #2 on: February 21, 2018, 11:33:13 PM »
If you are thinking of replacing, you might consider a silicone gasket.
This is just one brand, but one of the originals, AFAIK:
https://realgaskets.com/product-category/motorcycle/bmw/
« Reply #3 on: February 22, 2018, 04:41:06 AM »
I would tighten them by feel not least because I don't have a torque wrench I can trust at such a low setting. If I did have a small enough torque wrench I'd still aim initially a touch lower than the specified torque of 6 ftlbs.
« Reply #4 on: February 22, 2018, 05:54:13 PM »
When using the silicone replacement gasket
The issue is they tend to squeeze out instead of "torque up"
Even if installed clean and dry
I do not like them unless you have a problem getting the originals to seal
I used them on the valve covers until I had the surfaces milled
Now I use standard gaskets and the seal fine and they now "torque up"
Remember also the bolt under the oil filter needs the threads  sealed  because it is open to the  inside but can still bottom out on the filter canister
