Author Topic: Oil leak from the Brake Cam  (Read 3048 times)
« on: July 22, 2017, 08:35:49 PM »
 I  have been having  problems with an  oil leak from the brake cam
Of course it likes to leak when I am on a long trip
and get all over the side of the tire
So I am going try these
Mcmaster Carr Part #1200N185
I just install them today and I think they are going to work much better than the standard O ring that is specified in the Parts book
The feel like they have better tension in the housing and should seal better
I will  update if I have any problems
I have the type of housing that does not have the tube that the cam runs thru
« Last Edit: July 22, 2017, 08:38:00 PM by Mrclubike »
Offline peteremc
Re: Oil leak from the Brake Cam
« Reply #1 on: July 23, 2017, 03:42:34 AM »
Good luck.
I had the problem last year after re-assembling the bike without replacing the o-rings and was really scared by the amount of oil that had distributed itself around my rear tyre. Damn dangerous.
I pulled the shaft (because I didn't have anything to remove the o-rings without damaging them and it was about 30 minutes before the shop closed on a Saturday), went to a really great local auto-supplies store where they matched them, charged me about $1 and no problems since.
peteremc
« Reply #2 on: July 23, 2017, 01:02:52 PM »
Really interesting looking O-ring.
« Reply #3 on: July 23, 2017, 01:15:12 PM »
I've gotten into the habit of replacing these  O-rings every time I have a rear tire replaced .
Only takes 10 minutes or so to replace them .
Online Barry
« Reply #4 on: July 23, 2017, 01:58:48 PM »
So you used an O ring of larger section and in the new vs old pic,   new is on the left and old on the right with two O rings stacked on top of each other. Is that correct ?
« Reply #5 on: July 23, 2017, 02:05:45 PM »
« Last Edit: July 23, 2017, 02:16:35 PM by Bob_Roller »
« Reply #6 on: July 23, 2017, 02:48:22 PM »
No (I am pretty sure).
The old is on the left.  The new, which has a non-round cross-section (X-ring?), is on the right.
« Last Edit: July 23, 2017, 05:31:12 PM by Rob_Valdez_79_R65 »
Online Barry
« Reply #7 on: July 23, 2017, 03:49:37 PM »
I never saw an X profile O ring before.  The stuff you guys can buy at the local hardware store.
« Reply #8 on: July 23, 2017, 08:57:02 PM »
Rob is correct
original Oring is on the left the quad ring is on right
« Reply #9 on: July 23, 2017, 09:05:24 PM »
I had just replaced them less than 3000 miles ago  :'(
If the wheel is off it isnt much to change them
« Reply #10 on: July 23, 2017, 10:47:15 PM »
Do you use those quads in your work, Mrclubike?
« Reply #11 on: July 24, 2017, 08:58:16 PM »
Not very often usually they are just the round cross section type
