Author Topic: Indicator Weather Seal  (Read 1218 times)
Offline Adrian
  • The Old Hairy Biker Sez...
« on: June 21, 2017, 02:54:40 AM »
Hi there - it's now full steam ahead for the reassembly - well maybe half steam :-)
Anyway - I am in need of the weather seals for the indicators. I have a non - adhesive clear sealant but I would rather use the correct item.
I did locate some with an American BMW dealer for USD14 for 4 but they want USD75 to post them. this was the only dealer I could find that had them.
So can anyone guide me to a dealer who has these things - and maybe one for the rear light lens too.
Number 4 on the schematic attached
Thanks for any help .... Adrian
1984 R65 (860)
Re: Indicator Weather Seal
« Reply #1 on: June 21, 2017, 08:42:18 AM »
Adrian, the gasket is P/N  63 23 1 243 446 and is NLA.
But you can buy the whole indicator fixture (P/N  63 23 1 243 442) for a mere 32.62 € apiece at all BMW dealer.... And use the gasket instead of the whole assembly...
Are the original gasket that bad they need to be replaced ? Because buying second hand will provide you with questionable quality parts.... IMHO.
Offline Adrian
« Reply #2 on: June 22, 2017, 02:02:26 AM »
I've decided to go with the non adhesive clear sealant - it's quick and inexpensive and tidy.
George - the seals I have are crumbly and will only fall apart. Buying 4 new and complete units is far too expensive for me here in Australia .......... It would cost about $130 Australian whereas the sealant cost $15 :-)
1984 R65 (860)
Offline peteremc
« Reply #3 on: June 22, 2017, 05:01:47 AM »
Adrian, I see Motobins have the complete units for about $30 Australian (2 for $60). (P/N  63 23 1 243 442). Then add some freight costs but I've always found them to be reasonable. In comparison to this, I see a major Australian BMW parts supplier has the units for $60 EACH and not sure if the rubber is included.
« Last Edit: June 22, 2017, 05:05:58 AM by peteremc »
peteremc
« Reply #4 on: June 22, 2017, 05:56:13 AM »
You could simply go to Jenkins rubber and buy some insertion rubber of the the right thickness and make new gaskets - I only made two, but they worked perfectly.
Well to tell the truth I made 4, but only the last two were usable. I made the long external cuts by clamping the rubber between two pieces of wood sized carefully and the internal cuts with nail scissors and the a hole punch for the screw holes.
I am however drawn to Adrian's notion of using non-adhesive silicone - a bit of acetic acid to clear off any excess on the outside and you get a nice neat new gasket.
« Reply #5 on: June 22, 2017, 05:24:52 PM »
Have any local source for o-rings ??
A thin diameter o-ring may work as a substitute .
« Last Edit: June 22, 2017, 05:25:18 PM by Bob_Roller »
