Author Topic: Brake Caliper Seals  (Read 3535 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Brake Caliper Seals
« on: April 13, 2017, 12:59:34 AM »
See attached photos.....
You can see that the new caliper seal is in place. I am not sure how to fit the dust seal.
As there is a gap around the main seal in the caliper - does this mean that the dust seal raised edge has to fit into the gap?
Or is it sufficient that the dust seal only fits to the piston?
All the photos I took when I was taking it all apart aren't clear enough to show me what is correct.
Thanks ...... Adrian
1984 R65 (860)
Offline Adrian
Re: Brake Caliper Seals
« Reply #1 on: April 13, 2017, 01:35:29 AM »
Well I found a picture with the dust seal still attached to the piston. It clearly shows the dust seal having the same gap around it as the main seal. So I think I just managed to answer my own question.
Yay for digital photography when stripping things apart :-)
1984 R65 (860)
« Reply #2 on: April 13, 2017, 01:52:08 AM »
Liking those black calipers, Adrian.
It's going to look good
Offline Adrian
« Reply #3 on: April 13, 2017, 02:08:36 AM »
Thanks Chris - its all black and shiny at the moment :-)
1984 R65 (860)
Offline marcmiller001
  • "Luck is where opportunity meets preparation."
« Reply #4 on: April 13, 2017, 01:45:40 PM »
Black calipers are awesome! See attached...
Marc Miller
Pro Race Driver
Dodge Viper GT3-R / Porsche Cayman GT4 / Porsche 911 RSR
'82 BMW R65LS
« Reply #5 on: April 14, 2017, 02:52:13 AM »
Hello,
I'm surprised to see there is some gap between the seal and the caliper body.
IRC the seal goes into a groove in the body, is against the back of the groove, and extend into the cylindrical bore, pressing hard on the piston.
This seal deform itself when the piston move and this torsion gets the piston back in when pressure is released.
They are difficult to install.
So I wonder if you got the correct refurbishing kit ?
As per the outer dust seal, it attaches to the piston with it's interior hole and to the caliper body with the outer diameter. There should be grooves for this purpose.
Offline Adrian
« Reply #6 on: April 14, 2017, 03:11:00 AM »
Hi George and thanks - I'm just checking Munich Motorcycles to see what the kit they sell looks like - this kit was bought from Motorworks in the UK- It makes sense that the edging of the dust seal goes around the grove where I have that flat seal.
1984 R65 (860)
Offline Adrian
« Reply #7 on: April 14, 2017, 03:17:59 AM »
So having checked Moto bins - Munich Motorcycles and Motorworks web sites - they all show that the kit I have is correct for my 1984 R65 with Brembos.
So now I am at a complete loss .........
Here are the photos of the kit I was supplied with by Motorworks for my model.
One photo is from Motorworks and one is from Munich Motorcycles. As you can see they are identical kits.
I am very confused .....
« Last Edit: April 14, 2017, 03:34:28 AM by Adrian »
1984 R65 (860)
« Reply #8 on: April 14, 2017, 07:53:01 AM »
I may be getting confused as to which caliper we are taking about.  marcmiller's picture shows an Ate caliper and the dust seals are secured to the body of an Ate caliper with a spring steel circlip.  Don't know how the Brembo dust seals are secured but they are definitely not the same as Ate dust seals.
« Reply #9 on: April 14, 2017, 09:00:07 AM »
All the Brembo maintenance kits look alike. only the parts size change...
You, for sure, have Brembo calipers.
Now you have to check what are the piston diameter of those Brembo.
IIRC the BMW Brembo use an unusual 36 mm dia piston. So the seals you bought are sized for 36 mm pistons, and maybe your brake system had been tempered by a PO...
the square section ring should fit snugly into the caliper groove and extend a bit in the bore making the piston installation somewhat difficult (use the "grease" in the kit and nothing else to fit it.)
I confirm that the dust sealing rubber is hold by a spring by Mr ATE and Mr Brembo use the rubber elasticity to keep them seated...
Simpler and very effective also.
Hope this help.
« Reply #10 on: April 14, 2017, 09:19:37 PM »
Like George said They all look the same
You need to measure the diameter of the piston and order from that
It could be 36 or 38mm (F08)or 48 mm (F09) or the 32mm (F05)
Hope fully you have the 38 mm standard F08 Brembo caliper that is very common and cheap to rebuild
and not the expensive BMW OEM 36mm F08 (pain in the but)
This is exactly why I got rid of the OEM 36mm ATE  and replaced it with a standard off the shelf 38mm Brembo F08
Parts are very cheap and easily available  ;D
« Last Edit: April 14, 2017, 09:36:39 PM by Mrclubike »
Offline Adrian
« Reply #11 on: April 15, 2017, 12:47:03 AM »
Thanks people for all the advice - I finally understood what the problem was. After realizing that I had experienced a major Seniors Moment - I found that the original seal was still in the bore - no wonder I couldn't see the channel for the main seal.
Well - I am 62 with a neurological disorder lol lol - My friends think of it as Daft Old Buggers Disease........
1984 R65 (860)
« Reply #12 on: April 15, 2017, 02:05:48 AM »
Easy mistake to make, I could list the mistakes I have made but nobody would bother to read the list as it would be too long[ch128580][ch128563]
The good news is you know what to do next and great advice from all on the forum[ch128077]
« Reply #13 on: April 15, 2017, 05:11:12 AM »
Have you ever tried to ride an R65 with the steering column not torqued solid to the frame ?
Well I did that during rebuilding after the powder coating of the frame...
And I thought the handling was somewhat weird...
When I arrived at the friend's house he said that something must be wrong because the angle in the front department was not standard....
And I was just 58.....
Offline Adrian
« Reply #14 on: April 15, 2017, 11:40:56 PM »
Thanks guys - no doubt there will be many more Daft Old Bugger moments in the weeks to come as I go thru the rebuild process  [smiley=mad.gif]
1984 R65 (860)
