Author Topic: Cruise Control  (Read 2852 times)
Cruise Control
« on: December 06, 2008, 09:41:43 AM »
OK I searched first but came up with nothing so here is a new thread.   :-/
Does anybody use cruise control/throttle lock on the R65 :question
I'm looking at Throttlemeister,  Vista,  NEP, and believe it or not a large Silicon O-ring out of a Caterpillar Diesel catalog!!!  Where is that picture......
If you have pictures of your install, I'd love to see 'em.
Thanks in advance,
« Last Edit: December 06, 2008, 12:52:53 PM by Semper_Gumby »
Re: Cruise Control
« Reply #1 on: December 06, 2008, 09:51:52 AM »
Yikes! I just looked those up and yow are they 'spensive :o.
I have used the throttle screw thingie on extended rides and it does help. Justin had fabbed up a neat replacement for the throttle grip screw that had a spring and flip lever for quick on / off setting. Maybe if we ask he'd fab up a couple more. I'd still like to get one after the Holidays
« Last Edit: December 06, 2008, 09:55:25 AM by MrRiden »
Re: Cruise Control
« Reply #2 on: December 06, 2008, 12:55:34 PM »
O-Ring Throttle Lock!!!!
http://www.thestevensons.org/node/view/718
I just ordered two for about 8 bucks!  It won't work on the R65 as I have BMW heated grips but it will probable work on the BSA's (which have bar end weights).
Another picture:
« Last Edit: December 06, 2008, 01:01:00 PM by Semper_Gumby »
Re: Cruise Control
« Reply #3 on: December 06, 2008, 07:55:20 PM »
Rich, I've been selling the crap out of 'em on e-Bay.  If anybody wants one it will be about $33 shipped.
trolle
Re: Cruise Control
« Reply #4 on: December 07, 2008, 08:32:00 AM »
Does it work on an '84 r65 and how?
greetings from a clear and cold (38 F) north
VaSteve
Re: Cruise Control
« Reply #5 on: December 07, 2008, 06:57:40 PM »
Is there a thread showing this working/in action?
tks
Re: Cruise Control
« Reply #6 on: December 07, 2008, 07:54:20 PM »
Steve, not much to show, with the lever "down" your throttle returns normally and when the lever is flipped up it presses a delrin rod against the throttle tube to hold it in place.
Trolle, they work on any Airhead or early K-bike except for maybe the Mystic or R100R because I think the throttle is different...
« Last Edit: December 07, 2008, 07:56:20 PM by admin »
trolle
Re: Cruise Control
« Reply #7 on: December 08, 2008, 02:23:11 AM »
If you will tell me how they are installed I want one.
greetings from a grey and wet north (40 F)
aussie
Re: Cruise Control
« Reply #8 on: December 08, 2008, 08:59:12 AM »
+1 with trolle.  :)
Re: Cruise Control
« Reply #9 on: December 08, 2008, 03:29:05 PM »
It installs in place of the throttle screw.  If you don't have a throttle screw installed there will be a plastic plug on the underneath side of the throttle.
Re: Cruise Control
« Reply #10 on: December 08, 2008, 07:13:03 PM »
Justin...is the throttle lock you make switch from "on" to "off" position or all infinite positions in between to make the throttle drag a bit?
Re: Cruise Control
« Reply #11 on: December 08, 2008, 11:20:58 PM »
Sue, for all practical purposes I would consider it's operation on/off although I suppose one could "fiddle" with it and get different degrees of drag...
Offline Billmc
Re: Cruise Control
« Reply #12 on: April 06, 2017, 01:35:28 PM »
Resurrecting this thread.
Justin, are you still making these 'cruise controls' and if so how much are they now? I'm Interested.
Thanks, Bill
1987 R65 Silver
Re: Cruise Control
« Reply #13 on: April 06, 2017, 09:27:15 PM »
I have one but i just keep it locked all the time
I think they were called "Flip A Lever" Throttle lock
Re: Cruise Control
« Reply #14 on: April 07, 2017, 07:53:10 AM »
I have nothing to do with this eBay listing, just found it after reading this thread. Seems kind of pricey to me.
http://www.ebay.com/itm/Motorcycle-Cruise-Control-Throttle-Lock-BMW-/322475391181?hash=item4b1507f8cd:m:m5SLFwliqhgkQhUrRBIQINQ&vxp=mtr
