Author Topic: Cruise Control  (Read 2870 times)
Offline Oconner
  • Sunny So Cal.
Re: Cruise Control
« Reply #15 on: April 07, 2017, 12:19:32 PM »
Don't know what mine is called. Got it at a moto show. It has a rubber slip on ring about a half inch wide that you slide all the way down on the grip. Then you put a this plastic 'arm' over it and it grips. You merely push it down to your desired throttle opening and it holds it there. Close throttle all the way and it goes back to no effect. It works great and was a 12bucks I think. I will look when iget home to see if it has a name. Will work on any bike.
'82 r65LS
'72 Honda CL 350
'13 FZ6R
Re: Cruise Control
« Reply #16 on: April 09, 2017, 11:44:26 PM »
I think I still have the pieces laying around to make a couple.  How many might want one?  I'd probably do $45/shipped CONUS.
