Author Topic: Painting replacement battery cover  (Read 935 times)
Offline jp9094
« on: March 07, 2017, 04:17:59 PM »
Just received a replacement battery cover for my '83 r65 LS from Motobins in the UK. It is not an original BMW piece, but a copy (Their part number 98201A).
Have also got the appropriate spray paint (Polaris silver) but want to know if there is anything needed to be done to the panel before spraying. I was told it is primed, but I could "Flat off" the surface and reprime before painting.
Is it worth the trouble to do this? The color of the piece is black so I know I may need to cover it more than once.
Any advice is appreciated.
Thanks in advance.
Re: Painting replacement battery cover
« Reply #1 on: March 08, 2017, 10:57:45 PM »
Wash it good, wet-sand it with 400 grit, and squirt it!
Offline jp9094
« Reply #2 on: March 09, 2017, 12:33:37 PM »
Thanks for the reply!
