Author Topic: EPA equipment on a 82 R65???  (Read 3919 times)
10drum
« on: February 01, 2016, 06:45:41 AM »
Greetings,
I introduced myself in the chit chat forum. I recently picked up a 82 R65, which has been sitting for nearly 15 years. I've ordered carb kits, some filters, fuel lines, battery, and such. I've been restoring old Triumph motorcycles and MG's for a while now, but they have all been older than 71, so the motorcycles don't have smog control. The MG's I've done do. I think the PCV and fuel vapor recovery are good, but exhaust air modification do not add or help much.
This bike has what seems to be a PCV valve under the top cover which ventilates the crankcase through the carbs? It also has exhaust air "something" which is vacuum activated, equalization??, or what?
I'm not sure if I will keep the air box, or use some individual K&N filters on the carbs, I'm open to suggestions, but whatever I do, I'd like to know what to do with the smog equipment? I know the crank case needs to be ventilated, what is the best way to accomplish this without the air box? Can the exhaust devices be plugged at the heads?
These are just a few questions to start with, thanks, for all replies, Phil
Offline D Mann
Re: EPA equipment on a 82 R65???
« Reply #1 on: February 01, 2016, 09:05:03 AM »
Here is a good write up on what to do to remove the pulse air system. http://bmwmotorcycletech.info/pulseair.htm
Iwould stay away from K+N filters and keep the air box. http://bmwmotorcycletech.info/K-and-N-filters.htm
Snowbum has a wealth of info on his site, it is well worth looking through.
David Mann
1981 R65
ABC #14407
10drum
« Reply #2 on: February 01, 2016, 09:40:52 AM »
D, thanks for the link.
« Reply #3 on: February 01, 2016, 05:39:46 PM »
While you're droning along with the verbose Snowbum, locate his article and parts list required to eliminate the BMW Pulse Air System. You can thank the gubmint of California for their smoggy air laws that resulted in all BMWs sold in North America to be fitted with this pathetic add-on.
Dump it and ride happy.
« Reply #4 on: February 01, 2016, 05:51:54 PM »
The thread size of the fitting in the heads   are a standard metric thread.
So you do not have to by drain plugs if you don't want to.
Just get the shortest bolt you can find and cut it off and thread it in.
« Reply #5 on: February 02, 2016, 11:32:38 AM »
I much prefer to use the drain bolts with the Allen socket heads. Sometimes, it can be difficult to use a common hex-head bolt.
Offline D Mann
« Reply #6 on: February 03, 2016, 08:36:16 AM »
Someone put this link in another post but looking through it they have a kit of everything needed to plug all the holes for $15.00. Might save some time.http://boxercafe.com/startercover.htm
David Mann
1981 R65
ABC #14407
« Reply #7 on: February 03, 2016, 02:06:42 PM »
I bought a bag of socket headed chromed brass bolts/grub screws from a Chinese supplier for somewhat less than one BMW drain bolt would have cost. Worth considering, mind you if you are retro-fitting a complete bike (I was only swapping heads) the two timing hole covers might be the clincher that makes the kit cheaper.
