Author Topic: Guess the repair..  (Read 2412 times)
Offline Matt Chapter
  • <insert witty remark here>
Guess the repair..
« on: January 19, 2016, 10:29:47 AM »
Hint: The item in question is in the middle of the photo.
'04 R1150 RT ~41000 miles
Re: Guess the repair..
« Reply #1 on: January 19, 2016, 11:26:36 AM »
Dipstick is close to the middle
« Reply #2 on: January 19, 2016, 01:13:30 PM »
Recent tranny work so I'm going to guess <drum roll, please> CLUTCH.
« Reply #3 on: January 19, 2016, 05:24:12 PM »
Or what he broke taking the transmission off???
Looks to me like there is a chunk of aluminum that has been repaired in the engine case/bell housing just below the timing plug.
Offline wilcom
« Reply #4 on: January 19, 2016, 06:36:32 PM »
Broke the clip off the airbox ?
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #5 on: January 20, 2016, 01:31:21 PM »
It's the damn fuel line that goes under the airbox.  Had some leaky line from tank to filter so figured I'd swap it all out at once.  Such a frustrating repair to undertake, mostly consisted of taking things apart to get to the line.
The clutch seems fine, as far as I can tell!  No repairs to the engine case, I think those streaks are gasoline / crud residue.  All of the airbox clips jumped overboard during the repair, but none of them broke.
« Reply #6 on: January 20, 2016, 01:44:56 PM »
I've replaced the rubber fuel line under the airbox, with .250 inch diameter steel tubing that's about 6 ish mm, I used brake lines from an auto store .
I agree, way too much work involved to replace a rubber fuel line !!!!
« Last Edit: January 20, 2016, 01:51:21 PM by Bob_Roller »
« Reply #7 on: January 20, 2016, 02:11:42 PM »
When I replaced my fuel line I used a length of stiff wire from a coat hanger. Slid it in from one side and slid the fuel line over it from the other side. No problem finding the hole on the other side. Took about 5 minutes of wiggling and didn't have to remove anything.
« Reply #8 on: January 20, 2016, 03:59:58 PM »
He beat me to it!
« Reply #9 on: January 20, 2016, 04:53:21 PM »
You get the credit Monte. I didn't come up with it. I'm pretty sure I got it from one of your posts from a while ago.
« Reply #10 on: January 21, 2016, 10:45:18 AM »
I tried the easy way (this ain't my first rodeo), but the outer diameter of the fuel line I acquired  was ever so slightly too big.
Next time I'm going with Bob's steel pipe idea, wish I had thought of it this time.  How did you make sure the T fitting stays in the pipe?
« Reply #11 on: January 21, 2016, 12:00:30 PM »
Last time I changed my fuel lines I switched to an ethanol resistant Tygon fuel line I picked up at the local mower repair shop. Thinner walled line so there was no problem snaking it through. And it hasn't started to break down yet.
« Reply #12 on: January 21, 2016, 12:09:21 PM »
The data I have on the correct size fuel line is 7mm ID x 11mm OD. A lot of fuel line available these days is the high pressure reinforced type intended for fuel injection systems and that can have an OD that's too big.
Offline decorn33
  • Loving my R65
« Reply #13 on: January 21, 2016, 02:18:32 PM »
I replaced that section of line on my bike using the high pressure type which would not thread through, but I did it as an add on to a larger project when I pulled the transmission to replace the neutral switch, and lube the input splines. It was a snug fit, but I'm hoping it will last a good long time.
1984 R65
« Reply #14 on: January 22, 2016, 09:39:29 AM »
Ding Ding.  That's what I get for going to the FLAPS.
