Author Topic: Hey tubeless tire converters...  (Read 1179 times)
Offline dziadzu42
« on: November 22, 2015, 02:14:24 PM »
How about telling how you prepped your rims to accept  a tubeless valve, and what valve (size, manu. etc) you used.
Re: Hey tubeless tire converters...
« Reply #1 on: November 22, 2015, 10:56:04 PM »
Here is a thread I did about it when I switched from Metzeler's to Avon's
Like I said in the  thread I am very happy to be rid of tubes.  ;D
« Reply #2 on: November 23, 2015, 07:46:52 AM »
Tubeless running on my 1981 R65 for years without any issues. Have forgotten the source but have valve stem with a slight angle that gains space between stem nozzle and wheel web.
Check on-line for the stems. Specs will tell you what dimension the rim opening must be. Obviously, you'll ream and fit the stem from the interior prior to mounting the tire.
« Reply #3 on: November 23, 2015, 12:29:22 PM »
It would be nice if somebody would make a thread on the conversion and put it in the technical/FAQ section.  I'm tempted to do mine almost every time I change tires.
« Reply #4 on: November 23, 2015, 04:59:14 PM »
I wouldn't mind doing that but I don't plan on a tire swap anytime soon.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #5 on: November 24, 2015, 11:17:12 AM »
Finally decent weather.. shouldn't you be piling up the miles?  I know I'm trying to while I have the chance.
'04 R1150 RT ~41000 miles
