Author Topic: 1985 R65 Electrical Issue  (Read 4709 times)
Warbucks
« on: October 17, 2015, 05:31:58 PM »
I've recently acquired a 1985 R65 and I'm currently trying to get it roadworthy for registration. It's been in my Father's garage and has not been started for about 10 years.
I'm trying to troubleshoot three electrical faults;
1. The turn indicators illuminate but do not flash. I can hear the flasher unit (under the fuel tank) make a single click when the indicators are  switched on at the handle bars.
2. The horn is not working at all.
3. The headlight works, but the parking light does not come on in the rear light assembly.
I'm not certain if the brake light is being activated from the front brake and cannot test it yet. The master cylinder has been replaced but I have not filled the reservoir with fluid yet. The unit is sealed. Therefore if I pull the lever, the master cylinder will not return at this point until I install the other brake components and bleed the system.
All other aspects of the electrical system seem to be working as they should. Both fuses are intact.
Any help will be very much appreciated.
Regards,
Warbucks
Re: 1985 R65 Electrical Issue
« Reply #1 on: October 17, 2015, 06:06:49 PM »
on the assumption that everything was working when it was parked you will probably find that a "break/make" cycle on every electrical connector and a "remove, squirt with contact cleaner and replace" cycle on every bulb will probably get it all working.
The horn you dismount and drop onto a hard surface a time or 10, if that doesn't cure it - buy a new one.
While you are there, give all the handlebar switches a shot of contact cleaner too - followed by a shot of CRC or WD-40
« Reply #2 on: October 17, 2015, 07:13:46 PM »
Check the fuses under the fuel tank, they are lousy excuses at best for a fuse .
Check for corrosion and bend the contacts together a bit to get a better hold of the fuses .
Warbucks
« Reply #3 on: October 17, 2015, 11:00:20 PM »
Thank you lads! I'll get into that tomorrow. Just a quick question if I may Tony. I'm not familiar with the terminology "make/break" cycle. Does that mean disconnecting, cleaning and reconnecting all of the earth connections on the wiring harness?
Everything on the bike was working when it was parked in the garage. I'm assuming that 10 years of salt air is most likely the culprit. I've replaced basically everything that is rubber without opening the carburettors. I have a kit to do that when required.
I haven't tried to fire up the engine yet because its sitting on a hydraulic lift with the wheels off at the moment. Also, the tank has 10 year old leaded fuel in it. Somehow the key barrel on the fuel cap has been trashed, so I haven't been able unlock the tank to drain it out yet. I'm waiting on a new fuel cap and a barrel from BMW in Germany. $430.00 AU for those two items. They must be made of Stirling silver. LOL
I'm confident she'll go. The engine only has 38,000 kms on it. I know this to be true because I know the guy who used to own it. He purchased it brand new 30 years ago.
I'll let ewes know how I go with the electrics in a day or two.
Thanks again.
« Reply #4 on: October 18, 2015, 01:18:04 AM »
Exactly.
You will find with the big block connectors with the round male and female components that sometimes several make/breaks with contact cleaner and WD-40 will be necessary to dislodge the corrosion and get the electrons flowing again.
painstaking cleaning the electrics up was one of the most time consuming processes getting my R65 going after 20 years - like you I live in a salt air environment.
iwSVPyFzWDH
« Reply #5 on: October 18, 2015, 12:11:49 PM »
Agreed. Contact cleaner is your friend. No electrical connection on the bike is above suspicion. If you see a connection clean it.
The connections under the tank are especially critical. Remove the relays and clean their sockets.
Where the handle bar switches are concerned, spraying through the visible holes is not adequate, unscrew the switches from the bars and flood the back side of the switches, operate them vigorously and spray them again. Compressed air is handy as an interim step.
My '78 bike has responded very well to this treatment. I installed a small digital voltmeter and could observe operating voltage rising by tenths of a volt per fix.
The result is faster starts, more power/smoother running and brighter lighting.
Warbucks
« Reply #6 on: October 22, 2015, 04:57:05 AM »
I've drowned every connection on the wiring harness with CRC contact cleaner. That gave me low beam on the head light and a green neutral light. I hadn't noticed they were not working. After hitting the switches on the hand grips with CRC contact cleaner I could feel and hear grit in the contacts. More CRC and leaving them sit overnight made the switches feel like new.
I've yet to get the horn working. I'm planning to look at that tomorrow, but still no joy getting the indicators to flash.
Can I assume that the flasher relay has died? After all, it is the original relay and therefore at least 30 years old. If the relay is faulty, can anyone here suggest a suitable replacement. I was thinking that maybe a relay switch out of a Volkswagon might do the job as a temporary fix. I dread to think how much BMW will charge me for a new unit. Not only that, it'll be about 3 weeks before it gets here. I'm hoping to have the bike registered by then.
« Reply #7 on: October 22, 2015, 06:14:30 AM »
G'day, Warbucks
To confirm the condition of your horn, remove it from the bike and connect the horn's terminals to a known-good battery. If it honks, you'll need to trace the wires to find the fault.
One horn wire is a ground wire. You might jumper the brown wire (earth on BMWs) terminal somewhere else on the chassis and hit the horn button. If it honks, you have a ground fault.
The horn button could still be the culprit so a continuity check would be helpful.
There's always the possibility that an insect, such as a wasp, has built a mud nest up in the horn and has rendered it inoperative.
Take you old flasher relay to the auto parts dealer. Match up the pins and their terminal numbers with a new relay. The relay is a common unit used on VWs and other vehicles. They are very economical. I wouldn't waste time nor money trying to source a new relay from a Beemer dealer.
   After converting one of my R65s to smaller, LED turn signals, I spent $5.00 on a new relay that is designed for LED operations. Plug n' play.
You may also consider eliminating the old-school Euro ceramic and cheese string fuses. Newer 'blade' mini-fuses are easily tapped into the existing wires at the terminal box. BTW, toss the plastic box, too. Auto parts stores sell small, rubber, weatherproof fuse holders, too.
« Reply #8 on: October 22, 2015, 07:49:51 AM »
Regarding the OEM fuses on the R65s...
Dump this:
Buy a couple these:
Splice in the new fuse holders and secure in place with a zip tie. Done.
« Reply #9 on: October 22, 2015, 05:35:15 PM »
Do not buy a VW one,some of them have complex(read expensive) extra circuitry in them to detect failed bulbs etc. Unless the wiring harness to the 85 bikes is vastly different to previous models, just about any generic 3 pin flasher unit will work.
« Reply #10 on: October 22, 2015, 06:01:58 PM »
Don't know what's available in other parts of North America, or other parts of the world, but I've found relays in ' blister packs ' at most chain type auto parts stores, for under $10USD .
« Reply #11 on: October 22, 2015, 07:42:17 PM »
My factory Fuse holder was in perfect condition and it would still open up and lose connection.
Get rid of it like Monte says
Warbucks
« Reply #12 on: October 23, 2015, 12:53:28 AM »
I now have flashing indicators. The fault was in the 30 year old relay switch. A new relay fixed it. I tried a few cheap flasher units. They all had the same pin configuration as the original, but they all blew the fuse. I eventually replaced the unit with a NARVA relay switch (part number 68236BL). Although it wasn't cheap, I'm not complaining about the price at all. I'm just glad that it's now fixed and I'm a step closer to getting the bike registered. BMW wanted $110.00 for it. They've gotta be kidding!
I've checked the horn situation and it appears that the wiring harness is not the problem. The multimeter read 6.8 volts without touching the horn switch. When I activated the switch, the multimeter read 12.3 volts. I checked the resistance on the horn and it's completely dead. I'm guessing that the contact points are corroded. Rather than pry the horn open and completely destroy it, I've actually drilled a small hole in the side of the horn between the positive and negative terminals. I then sprayed contact cleaner into the hole and gave the unit a good shake. I'll leave it soaking overnight and hit again tomorrow morning. If that works I'll plug the hole with silicon. Failing that, I'll buy a cheap new horn. I don't care what it sounds like because I don't intend to use it. It only needs to be working to pass the inspection for registration.
As for the fuse box, it's not really a problem at the moment. I always say, "If it ain't broke ya don't fix it". If it poses a problem down the track I'll address it then. Many thanks to all who gave me input on this post. I shall return to let you all know the outcome when I get the horn sorted out.
 [smiley=bmw_smiley.gif]  [smiley=beerchug.gif]
« Reply #13 on: October 23, 2015, 09:33:47 PM »
You don't plan on using your horn :o
Most of us use our horn a lot.
I got rid of the original horn and put 2 Fiamm   Highway blasters in place of it.
« Reply #14 on: October 24, 2015, 08:07:19 AM »
Ditto the twin Fiamm horns. All my Airheads and the Triumph 900 have dual horns that really wake up the rolling texters, tweeters and chicks applying makeup as they wobble down the road.
When the event occurs that changes your mind about horns on motorcycles, and that event will happen when you least expect it, go ahead and fab a new, fused and relayed horn circuit. Loud horns pull more power than the tiny OEM 22ga horn button wires are designed to handle. You do not want the magic smoke to escape.
