Author Topic: Kick starter  (Read 2350 times)
Offline Andrewsteward
Kick starter
« on: December 13, 2014, 04:45:16 PM »
Does anyone have a lead on kickstarters for 81 r65?
Mine is broke and cant find a spare.
Re: Kick starter
« Reply #1 on: December 13, 2014, 09:03:41 PM »
Are you talking just the lever?  From everything I've read it's generally not a good idea to use a 5 speed box's kickstart very often due to it's fragility.  I have started our R65 RS one time with the kicker, just to verify it worked.  Too bad they are not as robust as the ones on the 4 speed boxes, I used the one on my /5 for several months while I was saving up for a battery!
Re: Kick starter
« Reply #2 on: December 14, 2014, 07:08:19 AM »
yes just the lever. Its not that I plan to use it, but mine is broke and would be good to have it in working order. I am sure one day I will have to use it
Re: Kick starter
« Reply #3 on: December 22, 2014, 08:16:23 PM »
I suppose you could get it welded back together or keep an eye out on fleabay.  I think they were a somewhat scarce special order so there are not that many 5 speed kickers around...  I suppose you could see if a lever from a /5 could be made to work, they would be easier to find...
