Author Topic: bent push rod.  (Read 1646 times)
Offline jakebass12
  • double clutching diesel demon.
bent push rod.
« on: May 01, 2013, 11:05:41 AM »
i was adjusting my valves today and noticed my push rod was bent so i took it out to confirm and unfortunately it was. so my question is should i buy a brand new one from maxbmw for $40 or should i get a used pair for $25 0n ebay?
1981 bmw r65. 1981 kawasaki kz550
Offline flybot
Re: bent push rod.
« Reply #1 on: May 01, 2013, 02:24:22 PM »
If it was me, I'd go used. You arent really getting anything more or less with a used push rod as long as its straight.
1983 R65
Offline donbmw
Re: bent push rod.
« Reply #2 on: May 01, 2013, 03:14:01 PM »
You need to look for the cause. Stuck valve.
Re: bent push rod.
« Reply #3 on: May 02, 2013, 01:39:47 AM »
And I am pretty sure I have a box full of them around here somewhere.  Yours for shipping.  I can send you more than one in case there is a problem!
If you ever have the jugs pulled away from the block for any reason, it is always a good idea to reach in with a magnet-on-a-stick and pull out the cam followers to make sure they are in good shape.  I believe is is only a Type 247 issue (R65s are Type 248 engines), but you want to know.
Offline Matt Chapter
  • <insert witty remark here>
Re: bent push rod.
« Reply #4 on: May 02, 2013, 10:59:40 AM »
Tell me more Rob! Since I've still got the jug off for my valve replacement, I'm getting pretty bored.  Is there anything else (grease) necessary for reinstall of the follower?
'04 R1150 RT ~41000 miles
Offline jakebass12
Re: bent push rod.
« Reply #5 on: May 02, 2013, 12:43:10 PM »
thanks but i already ordered 2 off eBay. and had them express shipped to me by friday. need them for a rally here in Wisconsin. but if i ever bend another ill keep you in mind. ;)
Re: bent push rod.
« Reply #6 on: May 02, 2013, 04:38:43 PM »
Nope - just drop them back in there (you may need to push them in with your finger).
If you want to get really anal about it, you could put some oil on the bottom where it contacts the cam lobe, and the top, where it pushes the push rod, but I don't think that is necessary.
Re: bent push rod.
« Reply #7 on: May 03, 2013, 08:07:11 AM »
Jake, What caused the push rod to get all bendy on you?
Offline jakebass12
Re: bent push rod.
« Reply #8 on: June 05, 2013, 12:41:12 AM »
hey sorry for the late reply. i think it was when my valve seat came loose and bent the valve and valve sleeve. i think it just bent a little so i didnt notice and over the time until it needed a valve adjustment i noticed it was bent.
Re: bent push rod.
« Reply #9 on: June 05, 2013, 09:45:04 AM »
Case closed!
