Author Topic: 1985 K100RS brembo calpiers  (Read 1731 times)
79beem
« on: September 23, 2012, 07:51:23 AM »
Evening Chaps.
Quick question.
Will 85 K100RS front brembo calipers fit a 79 R65?
Part numbers don't appear to be the same.
Anyone know the measurement between mounting holes or any other info, ie piston diameter, K100rs disc thickness.?
« Last Edit: September 23, 2012, 07:56:20 AM by 79beem »
Re: 1985 K100RS brembo calpiers
« Reply #1 on: September 23, 2012, 01:55:55 PM »
I don't believe those will work. The four piston brembos from early Ks will work on the monoshock R65 with slight modification, but I haven't heard of any substitutes for the early bikes.
Perhaps you can do the leg work for us and figure out which tokico or other Japanese calipers can be easily modded to work!
79beem
« Reply #2 on: September 23, 2012, 05:04:39 PM »
Wirespokes,
The ones I'm looking at appear to be two piston Brembos, that's what got me thinking they might be the same. Im sure I read somewhere that the yoke on the R65's was used on the later K's?  Might have to call the local beemer shop. Thanks for the reply.
« Reply #3 on: September 23, 2012, 05:13:49 PM »
79beemer, one of our members here, username JulioA, was doing some testing of what calipers may work on a twin shock R65 .
I know he was trying to make a caliper from a K series bike, but I don't know which one .
May want to send him a PM and see what he has to say about it .
One member here put an entire K75 frontend on his R65 .
79beem
« Reply #4 on: March 04, 2013, 03:13:03 AM »
Ok, this is a continuation from what I added to the recent Rotor post.
BMW R65 80 100 RT RS Monolever, 1989 K100RT, 2 pot (piston) Calipers should fit a 79 R65 and all later models having 108mm center to center between mounting holes.
Piston diameters do vary, but Snowbum recommends in his brake article fitting calipers and seeing how they perform before swapping the MC.
http://bmwmotorcycletech.info/brakes.htm
Its also possible according to Snowbum to fit 4 pot Brembo calipers from much later K and R's to our bikes with a small amount of milling of the mounting surface of the caliper.
I'm waiting to hear back from a chap with a pair of R1100RT R1150RT K1200 Brembo Calipers to confirm the 108mm spacing.
Thanks to Wavy Dave for his efforts and info. [smiley=tekst-toppie.gif]
 Â
« Last Edit: March 04, 2013, 04:10:17 AM by 79beem »
79beem
« Reply #5 on: March 06, 2013, 01:00:14 AM »
Feedback from sellers and other websites seems conclusive and supports Snowbums article.
The following 4 pot calipers have 108mm mounting hole centers
BMW #34112331627 Left Ride (non-abs)
BMW #34112331628 Right side (non-abs)
K 1  1989, 1990, 1991, 1992, 1993
K 100 RS  1990, 1991, 1992
K 1100 LT  1992, 1993, 1994, 1995, 1996, 1997
K 1100 RS  1992, 1993, 1994, 1995, 1996
R 100 R  1991, 1992, 1993, 1994, 1995, 1996
R 100 R Mystik  1994, 1995, 1996
R 1100 RS  1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001.
Also 34112333111 and 34112333112 K 1200 LT 1999, 2000, 2001.
There could be more but I feel that's more than enough to keep me going. I did notice the brake line was connected to the caliper via a banjo bolt on the K1200 LT.
Again, its not the caliper but the rotor offset which is the potential minor set back.
One chap 98lee on http://www.bmwmoa.org/forum/archive/index.php/t-33917.html
suggested
Quote. "As long as you have CLEARANCE on both sides of the rotor with NEW pads and the pistons bottomed in the caliper, it's ok.
The pads and pistons don't care if they are totally centered as long as they don't mechanically bottom out in the caliper and that the pistons on the side that is farthest away doesn't come more than half way out of the caliper when you have fully worn pads in place. Hydraulically, they see they same thing: psi/sq" of piston.
What IS important is that they are as parrallel as possible to the rotor, even with floating rotors." Unquote.
Any thoughts about this?
Hope this helps if anyone is interested.
Of course, if you want to do the upgrade do your own research.  [smiley=deal2.gif]
No responsibility taken here.
I intend to fit the calipers first with the oem rotor and asses the changes.
I will take some pics as things develop.
 Â
« Last Edit: March 06, 2013, 01:14:26 AM by 79beem »
« Reply #6 on: March 06, 2013, 01:51:24 AM »
The mono shock "R"  18" wheel fits the K series but it is not a "Snowflake" pattern as on the early R65,s and has Brembo brakes.
