Author Topic: "79 Points  (Read 2653 times)
Crossrodes
"79 Points
« on: December 19, 2012, 05:47:47 PM »
What is a good place to buy ignition points and condenser for a '79 R65.  I've bought them before but can't remember my source.
Re: "79 Points
« Reply #1 on: December 20, 2012, 11:50:39 AM »
Probably not going to be your first choice but if you can't find good ones locally Motobins have them at £6.65. They say 100% German made.
Beware made in china genuine BMW supplied points that had an over sized rubbing block. This was a recent problem reported for 70 - 78 points.  It's not clear if it also affected BMW supplied canister points.
« Last Edit: December 20, 2012, 12:03:44 PM by bhodgson »
livingdeadhead
Re: "79 Points
« Reply #2 on: December 20, 2012, 03:53:47 PM »
there are several specialists in the uk, only downside is postage to you.
livingdeadhead
Re: "79 Points
« Reply #3 on: December 20, 2012, 03:55:44 PM »
oh! motobins are doing an electronic ignition for your (our) bike for £70.00 . you wont have to set your points again!
Re: "79 Points
« Reply #4 on: December 21, 2012, 08:02:31 PM »
You still have to occasionally adjust the gap to compensate for rubbing block wear but the contacts will never wear out!
Offline jusgus
  • Doin good ain't got no end.
Re: "79 Points
« Reply #5 on: December 22, 2012, 09:16:39 PM »
I get mine from NAPA they are ECHLIN part no. CS313. I use them on my 1980 and they work good. I think that the parts guy once told me they are the same points that are used in VW engines.
Re: "79 Points
« Reply #6 on: December 23, 2012, 06:28:26 AM »
I've already done some research on this.
I have a spare set of genuine BMW points part no 12 11 1 243 969 for my 79.
According to my MITECH auto electrical catalogue there are a  whole range of alternative sources for these points equivalent to MITECH type CP-701.  Note they quote the correct BMW part no and the the photo is also identical to my spare set.
To confirm that Volkswagen air cooled 1964 - 1968 points can be used take a look at this article and you'll see something that looks similar to a bean can. Again lower down the page there is  photo of the points that look identical to my spare set.  Note the condenser looks the same as ours too.
http://www.volksworld.com/tech-guides/replacing-your-vws-points/
« Last Edit: December 23, 2012, 06:53:31 AM by bhodgson »
Re: "79 Points
« Reply #7 on: December 23, 2012, 08:12:50 AM »
Hello !
Although I didn't have points in my R65, I've checked this.
The BMW part is, according to a big auto parts stockist in France (oscaro.com), the BOSCH part 1 237 013 141 which is fitted to a, whaouh, Porsche 911 2.0 Targa with 160 CV under the hood and a monkey behind the wheel as said my Granny....
There is no doubt other points will fit with a little different length or connecting wire.
Hope this helps.
P.S. the price quoted by Oscaro is 4.78 € tax included each. If you plan to order you can add OX35 or OX37D oil filters or LX56 air filter for post 81 models...
« Last Edit: December 23, 2012, 08:13:06 AM by georgesgiralt »
Offline URon
Re: "79 Points
« Reply #8 on: December 28, 2012, 12:56:40 PM »
Ted's Beemershop in California.
http://beemershop.com/Merchant5/merchant.mvc?Store_Code=BS&Screen=PROD&Product_Code=12111243555N
Hi quality German made Noris points. Prompt service.
URon
Re: "79 Points
« Reply #9 on: December 28, 2012, 02:03:21 PM »
Uron
Norris points are a good recommendation as they are highly thought of in Airhead circles but unfortunately they are not correct for a 79 - 80 as the part No changed when they were mounted in the Bean can after 78. Couldn't see a set suitable for the Bean can bikes at Ted's Beemershop. Someone else might have them though.
Re: "79 Points
« Reply #10 on: December 28, 2012, 02:16:38 PM »
I've used the VW points. You have a choice with them, though. Normal and high performance - which has a stiffer spring. You'll want the high performance set since they'll handle the higher RPMs than a standard VW.
Session101
Re: "79 Points
« Reply #11 on: January 03, 2013, 11:53:00 AM »
bought from rick, cheap and fast
http://www.motoelekt.com/
