Author Topic: S fairing ?  (Read 10815 times)
Re: S fairing ?
« Reply #30 on: September 10, 2012, 09:39:32 AM »
... Sorry I questioned your sage advice.[smiley=deal2.gif]
Too funny. I really need to show this to Pretty Wife. She will certainly be  [smiley=ROTFLMAO.gif]
Couple other thoughts on finishing out (that's a chippy term) a fairing install:
Rubber grommets in a variety of sizes are available where ever hardware is sold. These cheap bits add a professional look to holes cut for turn signal stalks. They can also hide minor oops issues.
Both the ABS material and the plex windscreen can be edge polished after any reshaping via trims and/or sanding. Try to maintain a 90-degree sanding block-to-plastic contact. A tiny round over is OK but do not get carried away. I usually start with 400 and work up thru the grits to 1000. Wet-or-Dry used wet. Rinse the windscreen often but do not wipe the swarf away with a rag. The screen may be scratched. Rinse and blot dry.
There are several plastic polish products available that will remove or reduce hazing on the windscreen... although I've never been able to get my head down behind the low EMGO screen to check for bugs.
Re: S fairing ?
« Reply #31 on: September 10, 2012, 09:48:17 AM »
Monte did do an exemplary job on my fairing but then he is a craftsman about these things.  I must step in here though and say that the pin striping on the R90 are by Phorqs.  Various colors and widths are available from your local auto supply store.  Application is simple but do take time to plan the pin stripe design and where cuts are needed.  I'm a proponent of Less is More.
79beem
Re: S fairing ?
« Reply #32 on: September 28, 2012, 06:48:08 PM »
So here's another way to mount the Emgo viper/cafe/cockpit fairing.
I decided very quickly I didn't want to be drilling holes into the fairing until I tried it out on the road first and as I have low,short, flat non oem bars and a later model reservoir. Making it work meant new bars or major mods to the fairing.
So I sat the fairing on the indicator stalks and calculated the dimensions of extension brackets needed to make it work, bringing the headlight up and forward as little as possible whilst leaving the lower instrument shroud intact.
 I fabricated two 55mm x 25mm x 2mm plates out of old aluminium angle, drilled elongated holes for M8 allen screws 3mm in from each end. Then I reshaped (bent) the supplied brackets to fit flat against the inner surface of the fairing,trimmed the lower tail of the bracket to accommodate the large chrome headlight washer, cold gal (supplied brackets and washers) and painted them all matt black in under 20 mins.
The kit included 14 rubber and seven metal washers.I placed the rubbers between the screw/screen and screen/body and the metals between the nut and body.
LOCKTITE every fixing!!!
I did have to elongate the four rear body holes with a fine round file to properly align the screen.
I placed the extension bracket at approx 45' to horizontal between the large chrome and rubber headlight washers with a SS washer and lock/nylock nut behind the headlight mount. As can be seen in the bracket pic I did have to bring the final position forward so the length of the bracket could have been longer by 5mm+.
The supplied brackets although identical didn't sit in the fairing symmetrically and the headlight was a tight fit in the fairing also, so this created a delay in what could have been an easy fit until I achieved the best result. An extra pair of hands would have been handy here.
I used SS M8 allen screws and washers to connect the headlight to the extension brackets. As I opted for a slightly forward tilt I used black electrical tape as a temp to prevent glare on the inside of the fairing at night.
I latter fabricated stiffeners running between the upper screen/fairing tails and the instrument shroud screws to stop pivoting and vibration using the same angle as for the extension brackets.
All up I reckon on 4+ hours of fiddling,fettling and twatting about to get it right.
The only down side to this method is that there is a noticeable gap between the fairing dash and instruments, which exaggerates any alignment issues.
I'm very happy with the fairing both visually and practically.
It works well in deflecting wind blast off my torso, I'm 6ft', so the wind is felt around the shoulders, arms and knees but not in a negative way. It performs really well at higher speeds, braking the "Ton'' comfortably.
Pics on there way.
« Last Edit: September 28, 2012, 07:50:47 PM by 79beem »
fbenach
Re: S fairing ?
« Reply #33 on: September 29, 2012, 11:56:01 PM »
Neat!! for a second I thought I was seeing my own bike!!!
Excellent work, those extensions never came to my mind!!
Congrats!!
« Last Edit: September 30, 2012, 12:01:10 AM by fbenach »
Offline steven m
Re: S fairing ?
« Reply #34 on: October 02, 2012, 10:25:33 AM »
Nice job!  Now I suppose I will have to quit stalling and make my headlight extension brackets...
mrm
Re: S fairing ?
« Reply #35 on: October 04, 2012, 04:28:49 PM »
after much time and many c notes...
click on image for larger view
in all her oily mess, i present to you, 'Bevo', my lil' R 65 S 'ette'
still much to do, but i'm gettin' there.
« Last Edit: October 04, 2012, 05:11:09 PM by mrm »
Re: S fairing ?
« Reply #36 on: October 04, 2012, 08:22:48 PM »
VERY nice, Mike. Hmmm... BEVO. Burnt Orange. Oh, now I get it!
What's your take on next weekends Texas v Okie game? Mr Ash and Company are looking pretty good.
Re: S fairing ?
« Reply #37 on: October 05, 2012, 08:00:22 AM »
Interesting mirrors Mike.  What brand are those and where did you find them?
mrm
Re: S fairing ?
« Reply #38 on: October 05, 2012, 05:42:54 PM »
they're large, inexpensive. not the final choice but they got me rollin' for now. ken sean is the package name i have.
they're online at the bay - brandless.
here's a link
http://www.ebay.com/itm/BAR-END-MIRROR-REVERSABLE-VINTAGE-PART-BLACK-/150828072806#vi-content
mrm
Re: S fairing ?
« Reply #39 on: October 05, 2012, 05:54:30 PM »
thanks, and Thank You to all that contributed to the thread. so very helpful.
it's a different, better bike for me.
goin' with the horns even with brown down for wv.
it's fun either way.
« Last Edit: October 05, 2012, 06:02:42 PM by mrm »
