Author Topic: swing arm bearing lube  (Read 917 times)
Ron_S.
« on: September 11, 2012, 10:27:14 AM »
How do I know when I have enough grease in the swing arm bearings?  The book (Haynes) says grease it until the old grease is expelled and new grease is visible.  Where will I be able to see it?
Re: swing arm bearing lube
« Reply #1 on: September 11, 2012, 10:30:04 AM »
It will come out from under the large washer .
Ron_S.
« Reply #2 on: September 11, 2012, 10:31:10 AM »
Sorry.  '86 R65 mono-shock.
« Reply #3 on: September 11, 2012, 10:59:42 AM »
From  a parts site, looks the same as the twin shock bikes, minus the large washer over the bearing .
Ron_S.
« Reply #4 on: September 11, 2012, 11:17:12 AM »
It must have been in need of grease.  I've put a lot in there and still see no new grease.  I'll put in some more.  Thanks.
