Author Topic: Gear shift lever  (Read 884 times)
Offline Speyman
Gear shift lever
« on: July 13, 2012, 11:19:33 AM »
I recently purchased some nice new boots with a padded flap for the gear shift; unfortunately there is insufficient space to get my boot under the shift. It is not immediately obvious how to adjust the clearance, as I see no splines on the shaft nor threads on the connecting rod.
Anyone know how?
Re: Gear shift lever
« Reply #1 on: July 13, 2012, 11:21:08 AM »
The foot rest is adjustable, there are serrations on both parts .
Loosen up the bolt and adjust it, to where it works for you .
Offline Speyman
« Reply #2 on: July 13, 2012, 11:22:51 AM »
Thanks, Bob, I knew it had to be something simple.
Offline Air4Life
« Reply #3 on: July 13, 2012, 12:13:15 PM »
Couldn't an adjustment be made by shortening or lengthening the threaded rod ends?
sold:
1983 33.8 E. Oil & Trans ?
Batt 10/06/2011
RearT 35.5 Spline 7/12 &
T.O.Bearing
C.U. Paste 5/12
« Reply #4 on: July 13, 2012, 12:33:04 PM »
If you have that type of shift linkage you can .
The '78-'81 model year bikes had a fixed length wire rod shift linkage from the factory, no adjustments possible .
Don't know what model year bike the original poster has, so I assume it's the earlier version .
« Last Edit: July 13, 2012, 12:34:30 PM by Bob_Roller »
« Reply #5 on: July 13, 2012, 07:19:14 PM »
If you have the "wire" it needs to be replaced with something adjustable if you desire to fine-tune it.
