Author Topic: Inside of rear wheel, do I need a new one?  (Read 2221 times)
soliecirc
« on: June 09, 2012, 09:21:39 PM »
Sorry, don't even know how to explain it or what it is called. Rivets? Spline? Grooves? It looks worn down though. Should there be grooves or does it not matter? Please look at the pictures and let me know if I need a new wheel.
Thanks for your time and input, I know someone will reply, you guys are great.
Re: Inside of rear wheel, do I need a new one?
« Reply #1 on: June 09, 2012, 09:59:56 PM »
Can you post a picture of what it mates up looks like ?
Not real familiar with the mono shock rear wheels .
« Reply #2 on: June 09, 2012, 10:08:45 PM »
Yikes, that doesn't look good at any rate.
The twinshock models have a center hub that is riveted to the wheels' brake drum housing, and the center hub has a mating inside spline configuration to  match up with the final drive units' outside spline configuration.   If the monolever wheel design is the same setup, spline-wise, it appears that you badly need a new wheel.
On the twinshock bikes, if one can remove the rivets, one can replace that center splined assembly on the wheel if it is worn out and re-use the wheel.  I cannot see from the pictures that this center part is even removable/replaceable on the monolever wheel.  Hmmm.
« Reply #3 on: June 09, 2012, 10:48:22 PM »
There are four bolts that hold the rear wheel on, you can see the holes in the wheel .
Here's a drawing of the final drive, those are not drive splines from the looks of the drawing .
http://www.realoem.com/bmw/showparts.do?model=0462&mospid=51626&btnr=33_0646&hg=33&fg=05
« Last Edit: June 09, 2012, 10:52:04 PM by Bob_Roller »
« Reply #4 on: June 09, 2012, 11:01:56 PM »
That is a monolever wheel and totally different than the twin shocks. The four lug bolts hold the wheel on and needs no drive splines. It's possibly centered by the outside edge of that flange. But if the wheel has been working fine, no oil leaks, brakes don't pulse - I'd take a leap and say there's nothing to worry about.
I haven't had one of those newer models (paralevers, yes, monolevers - the R80G/S - yes) so can't say definitely there's nothing wrong, but I sure don't think so!
« Last Edit: June 09, 2012, 11:03:54 PM by tvrla »
soliecirc
« Reply #5 on: June 13, 2012, 01:56:24 AM »
Thanks for the replies. I'm going with wirespokes on this one being that it has worked fine and there has not been any leaking.
Thanks again
« Reply #6 on: June 13, 2012, 03:12:32 PM »
So those splines don't do anything?
soliecirc
« Reply #7 on: June 13, 2012, 03:15:58 PM »
Not on the monolever models, '85 and later from what I can tell and the feedback I have been getting
Offline Air4Life
« Reply #8 on: June 13, 2012, 03:33:08 PM »
Okay, this is a little confusing for me.  Does this suggest that the wheel you posted the picture of came from a wasted twin shock model that was then resurrected and used lovingly here on your machine?
sold:
1983 33.8 E. Oil & Trans ?
Batt 10/06/2011
RearT 35.5 Spline 7/12 &
T.O.Bearing
C.U. Paste 5/12
« Reply #9 on: June 13, 2012, 03:35:20 PM »
No, the wheel pictured in the photo, is for a mono shock bike, the mono shock bikes have 4 bolts to hold the wheel on .
No axle and a nut like the twin shock bikes have .
Offline Air4Life
« Reply #10 on: June 13, 2012, 03:36:44 PM »
Okay Bob, so what gives with the worn spline look?
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
« Reply #11 on: June 13, 2012, 03:47:07 PM »
Nobody seems to know, it's the first time anything like this been posted before and there very few R65 mono shock owners on this forum to get any idea what the wheel should look like .
It may have been something that was used during the manufacturing process of the wheel .
Or possibly the splines were damaged during a tire change .
« Reply #12 on: June 13, 2012, 09:03:56 PM »
They're possible just casting marks left from manufacturing. Who knows?
The outside of that area might have something to do with aligning the wheel to the final drive, but the center does nothing. And it certainly doesn't need drive splines any more than the wheels on your car.
raymr
« Reply #13 on: June 14, 2012, 07:35:21 AM »
I put new tires on earlier this year and I recall seeing something similar. The wheel mounts onto the hub just like on a car, and the only wear item is the braking surface.
Offline Air4Life
« Reply #14 on: June 14, 2012, 08:09:53 AM »
wirespokes:  That sounds very likely.  When they manufacture these hubs maybe they place it on a similarly splinned shaft (albeit less depth spindle) for trimming the excess material or some other finishing details.
« Last Edit: June 14, 2012, 09:51:08 AM by Air4Life »
sold:
Batt 10/06/2011
T.O.Bearing
C.U. Paste 5/12
