Author Topic: R65LS Rear Turn Signal  (Read 1421 times)
jgp1854
« on: May 23, 2012, 07:05:17 AM »
How do you tighten up a rear turn signal, noticed the rr is a little loose.  It can be rotated by hand on the shaft it is affixed to.
thanks
jgp
Re: R65LS Rear Turn Signal
« Reply #1 on: May 23, 2012, 07:49:30 AM »
Remove the lens, and you'll find a metal strap that goes over the tube the turn directional mounts onto, it's secured with two screws .
If the screws are tight, you may need to wrap a few layers of tape on the tube to get it to tighten up and hold the turn directional like it should .
« Reply #2 on: May 23, 2012, 12:16:39 PM »
I've found that the metal clamp gets distorted. Probably from over-tightening or the signal getting bumped.
Unscrew the fixing screws and remove the metal plate. Not the flat ones with the serrated edges - the one that the screws hold down to clamp the signal.
The solution is to carefully bend it back to original shape. Take a look at the two flats with the screw holes - they should line up but probably aren't if the signal is floppy. bend them so they do line up.
« Reply #3 on: May 23, 2012, 10:09:20 PM »
The tape method also works for floppy front turn signals on the LS as well - they tend to get loose at the attachment point where it slides through the fairing nacelle.
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #4 on: May 23, 2012, 11:27:10 PM »
Quality advice here by Wirespokes. I just performed this on a friend's rear signal stalks. The result was rock solid signals after carefully reshaping the hardware.  Inspect the hardware closely and the intent of the fitment. I think the original problem with the bike I dealt with was a result of misalignment and overtightening.
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
jgp1854
« Reply #5 on: May 24, 2012, 08:45:19 AM »
Thanks for the advice.  Went in and tightened up the two screws, they were loose.
jgp
« Reply #6 on: May 24, 2012, 11:02:20 AM »
Loose screws - I didn't think to mention that!  ;)
Simplest solution yet!
There's nothing like loose, floppy signals pointing off in the wrong direction and bent/tweaked mounting stocks hanging them off at weird angles to make a bike look shabby. And it's so easily repaired!
But I still recall the first time trying to figure out why the signals wouldn't tighten up - took a while to realize the little bracket was bent and to straighten it out. Over-tightening the mounting screws will bend the ears in and eventually won't tighten any more and the signal will then be floppy.
bruce_launceston
« Reply #7 on: May 25, 2012, 03:17:42 AM »
And if you want to tuck the rear indicators in a bit just cut the tubes down and cut and file a new square cutout to match the existing. Might stop them getting knocked around.
« Reply #8 on: May 25, 2012, 07:14:05 AM »
Did this mod on both my R65s after the first boot-knocking of the signal housings. Have approx 1.25 inch of mounting stalk showing. The signals do tuck in nicely.
