Author Topic: Sucking leaking sound from head  (Read 1372 times)
bangpaul
« on: April 29, 2012, 03:52:43 AM »
I just got home from a ride and noticed the strangest sound coming from my left cylinder head. It sounds like pressure escaping from somewhere moist -- I don't know how else to describe. A kind of wet sucking sound.
Any ideas? After a few minutes it stopped, but it was quite noticeably loud, and I've never heard it before. I'm sure I would have noticed. Had just taken it for a half hour ride to blow the cobwebs out.
Re: Sucking leaking sound from head
« Reply #1 on: April 29, 2012, 07:53:51 AM »
LOL   ;D
All of us have been concerned about that one at some point.
Did you wash the bike before going for the ride?
Did you hit a rain squal?
There are a few fins near the valve cover where trapped water merrily boils away, producing the sound you were hearing.
Offline wilcom
« Reply #2 on: April 29, 2012, 08:00:43 AM »
Mine sounds like "bacon frying" when it's boiling off moisture that gets trapped in the fins in the valve cover/spark plug area.
Could it be that ?
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
bangpaul
« Reply #3 on: April 29, 2012, 09:37:09 AM »
Wirespokes, we just had our first big rain for the season last night, so the roads were a bit wet.
Cheers. It was freaking me out.
« Reply #4 on: April 29, 2012, 09:48:10 AM »
Put this back in the memory banks and save it for when it happens to you , when you turn the key to the "ON" position and get a wheezing/whistling sound .
When you turn the key on, the ignition system fires both spark plugs, if a valve is open and there is enough of a combustible mixture still present in the cylinder, it will ignite, with the aforementioned sound .
fastcataz
« Reply #5 on: April 29, 2012, 11:09:19 AM »
From the title I thought you might be close to a group of politictions.
« Reply #6 on: April 29, 2012, 06:34:11 PM »
Like, perhaps, we're getting close to having a few more statesmen?  ;D
You've seen that signature line? Statesmen are dead politicians - and that's what we need - more statesmen!
« Reply #7 on: April 30, 2012, 12:02:51 PM »
My bike does that almost every single day.  It probably did it today but I went in to get out of the rain.
