Author Topic: Crankcase Breather R60/5 - hypothetical question  (Read 798 times)
leswaller
« on: April 25, 2012, 04:34:44 AM »
Guys
The crankcase breather pipe protrudes into the right hand air intake casing. This obviously obstructs the air flow to a greater or lesser extent. Is there any problem in shortening the pipe so that the end is flush with the side of the intake cover. My thought is that it would still work as there would be a venturi effect from the air going past it and would not restrict airflow to that cyclinder
Comments please from the technical panel.
Les
Re: Crankcase Breather R60/5 - hypothetical question
« Reply #1 on: April 25, 2012, 06:18:08 AM »
By definition if it's causing less obstruction then the air velocity around it and hence the venturi effect would be a little less. My guess is it would still work though. I don't recall the twin breather tubes on mine protruding much past the casing if at all.
Anyway of testing this out without making an irreversible modification ?
« Last Edit: April 25, 2012, 06:20:35 AM by bhodgson »
« Reply #2 on: April 25, 2012, 11:02:53 AM »
IF it is flush/smooth with the outside of the tube, there will definitely be less venturi effect.   There is a 'boundary layer' effect in the tube, so air moving along the very outside of the tube is not moving nearly so fast as the air towards the center of the tube.   But, how much of an effect is actually needed - I have no idea, perhaps not much at all.
