Author Topic: up grading the neutral light  (Read 1029 times)
scottyintex
« on: February 18, 2012, 06:21:33 PM »
I sometimes have trouble seeing the neutral light up on the instrument panel....bright Texas sunshine. Is there a LED bulb out there that would replace the neutral light? Has anyone figured out a way to make it brighter? Any mods to make it better?
Re: up grading the neutral light
« Reply #1 on: February 18, 2012, 07:04:35 PM »
nhmaf installed some  LED's in the internal lighting for the instruments, don't know if they would improve the neutral light or not .
Other than that, there's not much out there besides the wedge type incandescent bulbs .
« Reply #2 on: February 18, 2012, 08:59:55 PM »
These guys are a WHOLE lot brighter, use less wattage, and don't heat up the instrument.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini-wedge.html%23wled
Use the ones that are sort of cube shaped - a little light circuit on each face. The ones with five will fit, not sure about the nines. I know the nines won't work in the /6 style gauges.
At the very least install one of the illumination bulbs to get rid of the condensation problems. I believe the hot incandescents are the source of condensation in our instruments that rusts them out.
Don't change your charge light with one of these unless you install a bypass resistor, otherwise the charging system won't operate properly.
« Last Edit: February 18, 2012, 09:02:06 PM by tvrla »
« Reply #3 on: February 19, 2012, 01:45:01 PM »
IF we can find that thread, I think that the white ones that I used will JUST fit (barely) as the little plastic housing around the neutral bulb is close - somewhere around here I have some slightly different ones that I was going to try out for the neutral and hibeam indicators... will try to locate them to get the part number..
The superbrightleds place has quite a variety of choices - just don't use these LED units for the charge light OR the turn signal indicator on the R65 as both those functions rely on a larger amount of current flow and voltage drop to operate properly.
