Author Topic: sub frame mounting?  (Read 1497 times)
Offline jakebass12
  • double clutching diesel demon.
sub frame mounting?
« on: December 22, 2011, 02:01:46 PM »
i have a 81 r65 and i was wondering if someone could tell me how all the bolts and washers and nuts all go together right. i figured out how to get it all together but im not sure if there are any missing because someone took this apart before me. so any help would be appreciated. :)
1981 bmw r65. 1981 kawasaki kz550
Re: sub frame mounting?
« Reply #1 on: December 22, 2011, 02:34:02 PM »
On the top-front mount, the tapered, hex-head bolt goes in first from the inside.
On the outside you should have a wave washer, then the nut.
On the lower front mounts, it is just a standard bolt and washer from the outside with a wave washer and then the nut on the inside.
Both of those are illustrated here: http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=46_0074&hg=46&fg=05
The top shock mount bolts are M10x45 (mine are fine thread, I believe).
The bolts go on from the outside with a wave washer under both the head of the bolt AND the nut, as illustrated in this image: http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=33_0625&hg=33&fg=25
Tighten everything WELL!
Offline jakebass12
« Reply #2 on: December 22, 2011, 03:43:08 PM »
thanks allot. i guess i need to get some wave washers im missing a couple.
« Reply #3 on: December 22, 2011, 04:06:29 PM »
I buy my metric wave washers at both Lowe's and Home Depot. Handy and priced right.
« Reply #4 on: December 22, 2011, 04:24:03 PM »
Well that's interesting. Mine are the other way around which explains why the battery is a tight squeeze past the end of the bolts. Hands up anybody who still has the decorative caps #9 in the diagram.
My inclination exactly as we want that rear sub frame to be rigid which is why it's always been a puzzle to me that the recommended torque for these bolts is only 11 - 12.5 ft lb  Without checking the exact figures that's way lower than typical for a high grade 8mm nut and bolt. The only reasoning I can think of for such a cautious figure is that in this location a sheared bolt is just as dangerous as a loose one actually more so as there would be no warning of failure.
I think I compromised between what the book said and what felt right and gave them 15 ft lb
« Reply #5 on: December 22, 2011, 04:32:40 PM »
All of my caps are still there !!!!
Kinda surprising, as just about everything else made  of plastic has long since deteriorated !!!!
« Reply #6 on: December 22, 2011, 08:27:27 PM »
Rob Valdez 79 R65 wrote on Today at 15:34:02:
Barry, that was one of the many improvements made to the '81-on models.
« Last Edit: December 22, 2011, 08:27:48 PM by Rob_Valdez_79_R65 »
« Reply #7 on: December 23, 2011, 05:09:42 AM »
Something else to add  to the list of differences which gets longer all the time. Also probably means I never had the decorative caps.
VaSteve
« Reply #8 on: December 26, 2011, 01:59:11 PM »
I have never used this but it looks like a good place to get bolts...
http://www.theboltguy.com/
