Author Topic: pannier mounts  (Read 1519 times)
79beem
pannier mounts
« on: August 31, 2011, 08:20:27 AM »
Just fitted secondhand mounts to my 79 r65. The oem fiche shows a M6x45 bolt connects rear arms/bars? together, but the gap between mine is 80mm.
 There is a loop on the rear of the frame between the seat and stop light, i assume this is for aligning the mounts with the bolt.
The loop is 40mm long. So a 45mm bolt obviously wont work, and there is a 20mm gap between the loop and each bar/arm.
  I'm thinking  a longer bolt with locking nuts galore. Whats the collective experience and advice?
Re: pannier mounts
« Reply #1 on: August 31, 2011, 03:02:35 PM »
I never even thought to check what the OEM part was.  I just measured the diameter and length I needed and bought a bolt that fitted.
I don't remember that much of a gap between the rack and the bike parts though.  My local hardware store sells spacers, so maybe you can find something more elegant than a bunch of locking nuts?
Re: pannier mounts
« Reply #2 on: August 31, 2011, 07:29:19 PM »
I machined little spacers for the Dawg...
79beem
Re: pannier mounts
« Reply #3 on: September 01, 2011, 01:36:34 AM »
Spacers! Genius!
My left mount is a bit wonky. Prob crash/dropsy damage,
 which may explain the larger gap.
Did you thread bolt through loop on rear frame?
Thanks for the replies guys.
Re: pannier mounts
« Reply #4 on: September 01, 2011, 12:43:19 PM »
Sigh.  I can't retire until I get a mill and a lathe.
