Author Topic: Is this the right head for my R65LS?  (Read 798 times)
Red_Hen
« on: April 07, 2011, 11:06:03 AM »
Hi Gang,
I discussed this with Rob before purchasing but before I run the new head to the machine shop to get cleaned up, can I please get another confirmation that this is the correct head for my R65LS?  I believe some of the older ones had smaller valves?
The numbers say R65 BMW 335-234   R6 Si Cu
Here's pictures from the posting on Ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270715119582&viewitem=&sspagename=STRK%3AMEWNX%3AIT
« Last Edit: April 07, 2011, 12:17:14 PM by Red_Hen »
Re: Is this the right head for my R65LS?
« Reply #1 on: April 07, 2011, 12:36:29 PM »
The later series (1981-on) R65 bikes did have larger valves.  Earlier models had 38mm intake, 34mm exhaust, later modesl has 40mm intake, 36mm exhaust.
There is a way to tell from some numbers stamped into the head casting, but I cannot recall at the moment.  I suppose you can always measure the valve diameters!
Red_Hen
« Reply #2 on: April 07, 2011, 12:45:08 PM »
Definitely! I can ask my guy at the machine shop to measure them - I'm pretty sure this is the correct head and so did Rob Valdez.
