Author Topic: The Electrolux Crossover Pipe Solution - NOT!  (Read 2264 times)
« on: March 20, 2011, 09:54:34 PM »
Well, I gave it a try.
I was suspect about it working ever since my headers arrived because one end of the 'Lux pipe I had was not flared and I did a test fit in the living room and it looked like it had way too much slop.  But I had it on good authority that this was an option, so today I tried to install my new pipes.
I cut the electrolux pipe down to size, and cut a compression gap in each end using my old OEM crossover as a guide.
I started tightening down the first T-Bolt clamp (the smallest available) and it was nearly down to minimum diameter and the pipe was still very loose.
I pulled the pipe off of the headers and I could see that the compression gap had closed up all the way with no discernible friction on the header. :(
Into the trash bin it went and I now have $20 worth of clamps in my spares box.  >:(
So off to Motobins I go to see what they have to offer.
Not only is their OEM pipe cheaper than any I have seen Stateside ($69 USD), but they also offer a pattern pipe for $37 USD!  I have a pattern pipe on the way!
I decided to get my fasteners at the local hardware store...
I just wanted to let you all know since I've been advertising this "cheap alternative" for a few years now, but had never tried it myself, until now.   :-[
Re: The Electrolux Crossover Pipe Solution - NOT!
« Reply #1 on: March 21, 2011, 08:30:42 AM »
They just don't make the Electrolux parts like they used to!!!
« Reply #2 on: March 21, 2011, 08:37:56 AM »
I fitted the pattern pipe to mine no problem as far as i recall the only difference being the clamp is built in.
Offline k_enn
« Reply #3 on: March 21, 2011, 02:10:47 PM »
Electrolux parts suck.
k_enn
original owner of:
?1982 R65
? 2014 K1300S
« Reply #4 on: March 21, 2011, 02:11:49 PM »
It occurred to me that the larger bikes have larger diameter head pipes, so it may work on them.
But for the price Motobins offers, who cares?
« Reply #5 on: March 21, 2011, 04:00:42 PM »
$48.57 includes shipping costs to the U.S.
« Reply #6 on: March 21, 2011, 10:32:30 PM »
Rob - can you post the motobins part # - I may be in need of replacing my crossover on my R65, tho I need to find a way to paint it black..... black as night, black as coal... I wanna see the sun, blotted out from the sky... I wanna paint it, paint it, paint it, paint it black..
« Reply #7 on: March 21, 2011, 10:56:34 PM »
http://www.motobins.co.uk/displayfinal.php?q=88425A&go=GO
Motobins part # 88425A
And they have a rear crossover for those who need them.  I guess they are a different length?
# 88426A
« Last Edit: March 21, 2011, 10:58:21 PM by Rob_Valdez_79_R65 »
« Reply #8 on: March 22, 2011, 12:52:25 PM »
On the R65RS I found that 1" electrical conduit was a perfect fit!  Since we painted the rest of the exhaust system satin black the lack of chrome on the conduit was a big plus...
