Author Topic: Carburators  (Read 1108 times)
wxp
Carburators
« on: March 12, 2011, 08:49:33 PM »
Its a wonder what adjusting the valves will do for carburetor problems.
Also, any one ever try to  put a /5 head light on a r65?
Re: Carburators
« Reply #1 on: March 13, 2011, 05:45:28 AM »
Also, any one ever try toput a /5 head light on a r65?
An R65 headlight reflector and lens can be used to replace a /5 headlight to uprate the original 45/50 watt non halogen type to a modern H4 55/60 watt halogen bulb.
Not sure why anyone would want to do it the other way around unless it's the /5 headlight shell and instruments you like the look of ?  If so the 1st problem that comes to mind is the /5 tachometer is mechanical rather than electronic.
